Turn signal stays on with lights on CG
    In my daily driven 98 CG Accord my driver side turn signal stays lit when the lights come on...
    blinker works fine during the day until i turn on the parking lights/ headlights then the driver side stays lit.
    so while im driving half the car is brighter than the other lol
    this is a recent dilemma and i have not been messing with anything on the car.
    i have checked wire harness ground and theyre clean
    i have checked the bulb contact point and filament its fine
    the only thing left is to replace the entire switch on the column...
    anyone know anything or have this problem before?
    -Tyler
    Moved....
    Next time please post in Other Automotive for anything non-CB related.
    '94 JDM H22A: 178whp 146wtq
    If you say double dutch rudder, i'm banning you...
      thanks! i wasnt sure
      -Tyler
        Do the emergency flashers work with the headlights on? I'm guessing not that one signal flasher, so I think the combination switch. If not maybe a fried connector in the harness.
        ......father in law has it back again. Time to shine
          I have a similar problem with my Jbody. Whenever it rains it has rained the turn signals only stay lit. They may blink for like 2 or 3 times the. It's solid. In my case it's the relay switch. I just don't want to replace it since it's only effected by wet weather.
            Nope hazards do not work with headlights on
            i have narrowed it down to either one of the Dual-filament bulbs is bad or the switch itself
            -Tyler
              It should still blink fast with a bad bulb. If it weren't only with lights on I would say relay for sure. I think switch.
                I had this problem in my grand am, it was the relay not working. Try that first.
