Rubber Grommets\ gasket interior steering column
    any got part numbers or a clue if these still can be had ?
    im all tapped out on local pik n pulls so next shot is ebay or somewhere else on the net
    i need of the rubber that goes around turn signal, wiper arm, and column housing it self
    i have a feeling this is gonna be. good luck finding one sort if things
    Accords didn't come stock with a rubber on the turn signal arm or wiper arm. These are usually had off a 2nd Gen Legend or a 2nd/3rd Gen TL or an RL.
    Not sure what your talking about on the column rubber. There is a piece of rubber on the cluster trim / center console trim. It hangs down off of it and provides padding to the column and closes the gap making it more appealing to look at.
      yeah i have a little flap above the steering wheel/ column
      was hoping there was more .. seems pretty bare and exposed but it is kinda old
      thanks for heads up about where to keep an eye out
