sleeves
    Treadstone seems to be decent stuff, and their prices are reasonable. I have no experience with them, but if I chose to go turbo, that would likely be my first stop. As for the radiator question (sorry for not seeing it until now), err on the side of caution. If you're not sure, go with the half rad just to be safe. A quality half rad and a good fan should provide sufficient cooling.
    yea i think im going to get a koyo 1/2 rad, but i think i will have a custom made manifold just because the treadstone one is 315$ then another about 100$ for a good t3 to vband adapter, so 415$ for a log style manifold seems a bit dumb to me. when custom made ones are probably around 6-700
      That's true.
      Keep in mind that the earlier 4G63t manifolds (1st and 2nd gen DSMs) fit on the F22A head (assuming you're still going with the F22A, I haven't re-read the thread) with relatively minor modification. You might be able to pick one of those up, since there is bound to be a better aftermarket for turbo manifolds for the 4G63, even now. You only need to redrill a few mounting holes, OR just get an F22A flange put on it. Ports line up perfectly.
      Might save you a few bucks.
        That's true.
        yea i sorta looked into this, but all i can seem to find is ebay crap
        or they are like 1000$+
          I would get a decent brand ss manifold. Like a obx and cut the flange and weld a v band. It's easy simple and sorta cheap. Obx Rams are about $250. V bands are about $30.
          my new turbo build
            I'm not sure I'd consider OBX a decent brand. They're really just another ebay knockoff brand. Just one of the older ones...
            Granted, their stuff often does seem a bit better than the usual generic junk.
              yea ive heard most OBX stuff is junk, and not to use it. I'd really actually like to see if anyone has any experience with their turbo manifolds
                have you used a OBX manifold before? or on your new build? your link in your signature doesn't work.
                  http://www.ebay.com/itm/OBX-Steel-Tu...f09954&vxp=mtr
                  http://www.ebay.com/itm/OBX-Turbo-Ma...922b3b&vxp=mtr
                  http://www.ebay.com/itm/OBX-Turbo-Ma...f08e80&vxp=mtr
                  it actually seems as if obx makes 3 different ones(2 of them are for h23) but the 2nd and 3rd look really close to the same design but maybe a bit different? or maybe my eyes are crazy. but the 2nd one says its made from 321 SS vs the 3rd one says t304. but what i dont get is why the 321 is cheaper than the other because 321 is better quality and very expensive. i dont really think they used 321. BUT from the "specs" they actually give they seem like they might hold up?
                  http://www.amazon.com/OBX-Header-Man.../dp/B008N2BFME
                  better priced, but these are only 16 gauge pipes. doesnt this seem a little bit thing(.060 inch)?? ive never really had experience with turbo manifolds
                    No actually. I have one of the cheap ebay knock off ss tubular manifolds. Honestly it's been more of a head ache then the stock dsm Manifold I had so much problems with both. But that's me. I want a ram style one tho I like the look and how they perform. If I had the option again to get the ram I would....what I would do how ever is add a few supports to it so it dosent flex as much.
                    This should work
                    http://www.cb7tuner.com/vbb/showthread.php?t=202937
                    my new turbo build
                      This should work
                      yea i think im going to get a ram or a mini ram done from a local shop
                        was also thinking about an oil catch can, are they worth getting? or is our PCV system good enough to handle it? i think capping the intake and just putting a filter on the valve cover would be a good idea because of all the positive pressure in the intake while in boost would back pressure towards the pcv valve closing it
                        also would there really be a benefit of using say like a greedy or mishimoto one over a cheaper 25$ one from amazon/ebay??
                          also anyone know of a good crankcase ventilation setup? or is the stock vent'ing going to be sufficient? im going to run a oil catch can from valve cover to oil can to intake also
                          ive been looking through most of the high turbo builds on here and i dont see anyone listing crankcase vent'ing, but everyone runs a oil catch can, so im hopefully guessing that it wont need it
                            Also wondering how people are running coolant through their turbo set-up where do you get it from and where do you put it back in at?
                            ive read pull it from one of the intake ones but just seems a bit weird to me
                              does anyone want to share how they have their coolant run through their turbos?
                                got my block and head back yesterday
