OK, so I was checking around on a civic forum for this info, which I am no member of, and I wound up gettin ITR DC5 suspension for the front and back. Now my problem is what axles can I use to mate this suspension to the differential in the tranny. I know that the base type RSX suspenion has the same spline as the civic but the type s and type r splines larger. Any insight will be a great help.
Help with 5 lug swap on 05 Civic
you dont need ITR DC5 parts. any DC5 suspension set up will work. also the civic SI of 04-05 also will work sence its 5 lug too. & use your stock axles.
also join http://www.7thgenhonda.com/forum/ Im there too
93 Accord LX Sedan (sold)
