I think I will send an email to xenocron, and see if an ecu would cause problems similar to what i'm experiencing.
DBSHARP'S F22B DOHC All-Motor Thread
I finally got my idle where I want it at 1k, it has been at 750 rpm for so long and its been bugging me. Moving idle resume was set to 750 in the advanced idle control, I never knew about the advanced idle control. Now I don't get a massage at the stoplight . I added a grounding strap into the ground for my ecu and lc-1. I'm going to add ground straps to the block to chassis and block to battery. I think that I am going to restore the ecu's ground point back to the factory location in the harness just to see if it makes a difference. After that I'm about out of ideas. I can't stand to have my car lean out so much when there is an electrical load, and I'm tired of just dealing with the problem using closed loop o2.
Since last time I tuned my car, the tune has changed dramatically. I used to have 14 afr's light throttle, now I have 12's. I think this is from changing the fuel pump.Last edited by dbsharp; 07-14-2008, 01:12 PM.spin city
Wohooo!
The ecu is the culprit!!!! After months of work and trouble shooting I finialy figured out why it leans out! I went to turbo tune and tried out a couple of ecu's mark had sitting around, and it dosen't lean out with them. Now lets see if Chris Harris stands behind his product.spin city
I got a new po6 and that fixed my afr's leaning out with electrical loads. I still have a fueling/ electrical issue. Heres what happens, my afrs's just go plain nutty and bounce around from 12-20 sometimes, and sometimes for some reason my ecu does not do a fuel cut when I come off the trottle in gear, random stalling also (I think this is part of the fueling problem). Most of the time these two events happen around the same time. I'm going to replace the pressure regulator just because that is then only component in the fueling system I am not sure about. I have even tesed the fuel injection harness for resistance and continunity to gound/ other injection wires, and it is fine. TPS is solid as a rock everytime I data log, and strangly this has never happened while logging. I just started making a new bin with a fresh p72 code, All I can think Is maybe that is corrupt. I am so frusterated with my car, Im thinking about getting a crx or a hatch and swapping the motor into it. If I get this figured out, I will probibly get a 16g dsm setup instead of continuing na.spin city
