F22a exhaust manifold flange
    I need to find a f22a exhaust manifold flange made from mild steel. I drew up the plans for it in auto cad and if I have to Ill pay a local place to cut it with their cnc laser cutter.
    The flange is more complicated than it looks at first glance, and the dimensions had to be broken up into three different groups due to the number of dimensions on the drawing. I think that it might take a while for the guy to program the cnc machine, which means that it will be an expensive part. I just want to know where else I can get them.
    I know some of you have made manifolds so let me know where you got your flange!
    spin city
    Could always cut one out you self. Plasma cutter the grinder. Or take a header not in use and cut the flange off.
    "The Turtle"
    DD/Trail Rig/Mud Bug
      yes I could cut one myself and clean it up with a grinder. I would still want to have the bolt holes to be drilled on a mill so they have accurate locations. I can find flanges for other honda motors, but I haven't found any for dsm's for some reason.
      spin city
        http://www.prostreetonline.com/s/fab...old-flange.asp
        I <3 G60.
          You need to get on realhomemadeturbo.com, especially if you plan on doing turbo setups for cheap.
          http://store.weirtech.ca/catalog/
          3/8", laser cut, mild steel. $22.
            you the man!
            spin city
              I placed an order for these flanges on the 14th, still haven't gotten and email or any sort of communication about my order. I am about to order a dsm flange from somewhere else so I can start making my manifold. Some of the dsm flanges come with a cnc tapered port to mate the exhaust port up to the pipe.
              spin city
