quick steering and suspension question.
    Hey guys!
    Thank you for the tip on the cv axle i really appreciate that.
    I am planning on totally redoing my suspension just to bring it back to a stock feel and since nothing has been touched on my 91 accord lx auto since it was made.
    I got the kyb strut plus, i got all my control arms from either moog or delphi. i got tie rods and all from delphi also. I got oem disks, drums, and brakes straight from honda. i would have brought oem if i could but i couldnt find the parts. (grabbed moog because i recognised that name more and delphi cause the guy at advanced said it was the top quality they could order besides moog.)
    i was gonna also redo my wheel bearing and maybe hub assembly. but im not sure what are my best options. i was looking at part number 44200-SM1-008 for the front which i think is just the bearing. i dont know how to pick the back ones.
    what would you guys recommend and just general tips.
    I thank you all for everything this place is great!
    You are correct, 44200-SM1-008 is the front wheel bearing only. The hub part number is 44600-SM4-020 (no longer available from Honda). If your hubs are good, the bearing can be replaced; it does take some work to remove the old bearing and install a new one.
    The rear bearing and hub assembly is part number 42200-SV1-008.
    A good source to find Honda part numbers (and parts at about 30&#37; off) is www.hondaautomotiveparts.com
