Hello I have a 1990 HONDA ACCORD EX AUTO F22A1 noticed when flooring it while at steady speed of 35-50 I push the pedal all the way to the floor it goes up to 3-4k rpms takes a few seconds 3-5 second delay it starts flying and goes up to 4.5k-6k also I am not sure if it related but I do have a exhaust leak and when I let off the gas I hear popping in the exhaust is that normal with a small exhaust leak? The transmission fluid looks good but can't say when its been changed last since I haven't changed it yet as of two and a half years ago when I bought the car. Also seems like some possibly hesitation or something maybe in the engine?
Delayed Throttle Response
that popping is definitely because of the leaky exhaust and you can loose some power too. if it is a small hole you can take a beer can or pop can cut the ends off and clamp it on for a temporary fix. for the hesitation try fuel system cleaner and a tune-up if it has been a long time since it was done. the tranny i have a m/t so i got nothing.
I have owned about 5 CB7's now, auto and manual. The tranny fluid rarely needs changed, if ever. Only time I would change it would be if the color is more brown or black than red. Tranny fluid should be red in color. With every auto I owned, I drained a lil fluid out, and added a court of Lucas Tranny Fix, as a precautionary move. You can buy Lucas at almost any parts house.
And, any muffler shop worth their salt should be able to weld up a small exhaust leak for next to nothing. I'd check into it.
Also Check Throttle cable slack good video on youtube from Eric " the car guy " who calls this video " free Horsepower " lol but it could help your cause to check and tighten if need be you should be able to eyeball and guess if slack is too much. It needs some but if at W.O.T its bent like a yoga instructor its slacked out too much . Heres link https://www.youtube.com/watch?v=rawvJop772E" Insert funny quote here "
