safety restraint system
    anybody got info on the auto seat belts mine do not work i've checked fuses and such anybody else have this happen to their cb7?
    Could be your door switch. There is a " computer " under your passenger seat which I do not know the name of but fixed my problem. If it's your door switch you will not hear the warning that your keys are in the ignition with the door open. This next part is just a guess but if you our headlights are on ...edit...and your car is off ...when you open the door and don't hear the warning it may be that box. Another edit, mine was just loose wires going into that box. Your stuff gets under there like tennis shoes or water bottles and moves around.
    ......father in law has it back again. Time to shine
      thanks for the info i'll check it out . didn't know there was a box under there.
