clutch recomendations
    I didn't see any vendor recommendations anybody have any thoughts on the eclutchmasters stage 2 with 12lb flywheel?
    To help you and give you recommendations, we are going to need to know what your goals are for your car. Is this a daily driver, a weekend track car project, a show car project?
    MRT
    Selling on Ebay!
    15.10 @ 90.42mph
      Get a quality clutch that is designed for the power your engine is making. If you're not making more than 150whp, you don't need anything more than stock. A "better" clutch isn't going to offer any performance benefits, and it will only cost more, and wear out your flywheel and pressure plate faster. Clutch material, like brake pads, will cause more wear on the friction surfaces with more aggressive material.
      Just buy a quality brand, and you'll be good. Exedy makes fantastic products.
      A 12lb flywheel is a decent weight for a daily driver. Light enough to notice the difference, but not so light that it's annoying. I have a 12lb flywheel myself. When I bought it, I debated getting lighter. Once I installed it, I was happy that I didn't.
          soon it will be 150 hp very soon want to do a turbo'd f22b. one day i hope to be maiking 500 hp daily driver
            I know that Saturn S Series aftermarket oem style clutch kits were not all considered to be of equal quality and that the forum members suggested strongly to get a Luk clutch kit for those cars. I did and it worked awesome and cost me only 4125 as well does anyone here use a Luk kit on there CB7/CB9?
            " Insert funny quote here "
              The Prelude H22 clutch bolts right up. I use an OEM H22 clutch for my NA builds. Of course, if you are turbocharging, you need something stronger.
                That's good info too know about the Prelude clutch mounting right up , you gotta love how much Prelude stuff swaps riight in.
                  I got a Barnoff stage 2 off of ebay and its supposedly rated for up to 300 HP. Its a nice, firm clutch, good for the money..
                  Procrastination is a THIEF of time!!
                  MY MRT
                  http://www.cb7tuner.com/vbb/showthread.php?t=203992
                  My First CB7
                  http://www.cardomain.com/ride/705233/1990-honda-accord/
                    the eclutchmasters one is rated to like 327 hp i got a good deal on it and i bought it before i found you guys. was just wondering if anybody had ever used this company and if you had how was your experience with it.
                      Wondering....
                      looking at about 400 hp.. What kind of clutch set up would be best?
                        A clutch designed for 400hp.
                        Please don't hijack other people's threads.
                          Getting a clutch that handles HP is great but your main concern is the torque the clutch can handle and also clamping force. Other key things is to consider is what type of pressure plate you want not all clutches fit every drivers preference. And just like any part you buy not always dollars spent equal quality parts. I would look more at the brand Competition Clutch.
                            I had ACT 6 puck sprung on my old turbo 240... never had any problems
                            I have a Unsprung on my cb7 right now and i def liked the sprung one better.
                              personally i hate clutches that are rated in HP they should be rated in torque. if a motor spinning 8000 rpm makes 500hp and another engine spinning 4000 rpm makes 500hp the engine spinning 4000rpm will produce twice the twisting force as the 8000 rpm one.
                              anyways i went with the action clutch 2ms from bisimotos store. good for 500+ hp
                              my build
                              http://www.cb7tuner.com/vbb/showthread.php?t=202734
