My Cb7 Up And Detonated
    So, im driving my girlfriend home on my oh so suspended license.
    Previously i had been driving all day-ish
    ok, im driving. i got a weird loss of power. i disregarded it we were on a hill. on the way down. i lost my cluster. all needles dropped. it was extremely haunting.
    cars still running. purring along.
    headlights DIMMED majorly.
    car started to shudder,
    kept crusing. it didnt affect anything.
    Then. It died.
    started it by doing a compression start while rolling.
    it started.
    started driving. then lost all power and started backfiring.
    it sounded alot like my 45. bang bang bang bang. not just a single. but it would do it in like .25 second intervals. then it died again
    the only thing that popped into my head was i replaced the ecu with the A6 instead of the standard one in my A1
    popped the hood. and looked. spark plug wires were arcing across my head and the other pieces of metal under the hood,
    AND when i push on the positive lead/terminal while the car is running. it dies
    WTF HAPPENED TO MY POOR CB?
    thanks guys
    Spark plug wires are fucked.
    Coil/Igntor are going out.
    wat?
      yeah
      thats what i was thinking....but that doesnt explain the dash cluster or lights
        Yeah it does.
        wat?
          it does so. just replace the coil, ignitor, plugs and wires.
          you should be good.
          why did you put an A6 ecu in there?
            you should be good.
            A6 has a different fuel map for 10+ HP
            I think also your ground or positive wire may be loose on your battery.
            But try replacing just your wires first.
            The insulation wears off and its like 20,000 volts going through the whole car...
              Nope, thats the p12.
              wat?
                I hope you get your problems sorted out, but I hope you stop driving on a suspended license even more so. Bragging about it does not make it cool.
                  x2.
                  -mak
                  Bought From: MadSpleen85, jimy, CB7_ACCORD (kouzie), Chrisfrom1986
                  Sold To: vinbon63, chessboxer, darkfusion42, LowNknoxville, bowzil, 1993hAccord, mcdizzle, 93accordfreak, lilb_1979, rocketman_471, Bad_dude
                  Traded With: cb95spd, chessboxer, sohc em
                  [ Completed | Pending ]
                    you can also check the alternator my car use to do similar like my needles would drop & the lights would dim music would cut off, & it was cause the plug kept popping off, so it wouldnt recharge the battery... just an idea...
                    2004 Accord Sedan CM6 (daily)
                    Koni Yellows, Hood Bra,Splash Guards,Deck Lid,Weather Mats,Sunroof Visor,Fog Lights <-All OEM, Mugen Door Visors, 07 Tsx Wheels.
                    1990 Accord Coupe CB7 (project)
                    H22 Swap, Skunk2 Springs on Koni Str.t, Rear Disk Swap, Fog Lights, 92-93 Trunk Conversion, 02 Accord Rims
                      thats weird i was driving home from work today and the needle on my speedometer dropped, it took a few seconds the went back up. whats up with that?
                        Thanks guys
                        i cant thank you enough.
                        im not braggin it just took me all day to drive out there. literally.
                        im sure youd do it for your girlfriends if they needed it.
                        but yeah
                        as for now. im buying the spark plug wires.
                          Vss? just a thought not sure.
                            Did you know that if you are caught driving on a suspended license in CA, the police can impound your car? And the ticket is more expensive than a DUI. It could cost upwards of $3000 not including the towing and impound fees.
                            Just food for thought...
                              Its The Alt
                              thanks guys. i appreciate your help.
                              MORE THAN YOU KNOW
