i have a ? about my wagon..i cant find the latch/lever for the hatch release,so did wagons bring a latch/lever for the hatch?i mean i checked around the driver seat were the gas door popper is and i cant find it,so im wondering if it doesnt have one or if its missing,so can anyone help me out?thanks..
wagon question..
just get the cable from a saden if that is not the right length try geting one from a ford taurus wagon and use the stock latch or use a saden latchLast edited by blazedealh91; 08-18-2010, 06:48 PM.
Originally posted by 87awwhelznaww92 View Postow dang...to the drawing board...diy lever!haha...
oh so it means i gotta use my key always???dont that suck!?...bummer...
Originally posted by quaidum View Postyes it does have a handle just like /\/\/\/\ said
you cannot see it but it is in the area between the taillights right underneath the honda "H" symbol
Originally posted by 87awwhelznaww92 View Posti know about that one i was reffering to an inside handle so i wont have to keep using the key to open the hatch...thanks for the help you guys..ill probably think of something to make it open from the drivers seat...ill give the sedan cable a try see if it works...
if the hatch is unlocked then you use the handle unless your handle doesn't work
if that is the case then fix the handle before adding something that doesn't belong there
