I need help,
My car has been running rough for the last couple weeks.
I did some reading on here to try and find the same symptoms as my car.
I found where somebody said that they had oil in my spark plug hole.
I took out all 4 of my spark plugs, one at a time. Looking at the engine from the front of the car, I removed the plugs from right to left.
When I got the the third plug, there was oil all around the threads. And also the plug had massive build up of oil and dirt around the prongs where the plug sparks at.
I cleaned this off, and the car did run a little better for a short while. Not its back to running bad again.
Can someone please tell me what I need to change to fix the oil around the plug problem?
Do I need to change the valve seals? or, the valve seal covers? Im not sure.
Please help,
Cole
Please help,
Cole
