Get used head from J/Y for around $300 or less, practice on your blown one, just take off and put beck on, if you can do that than go and buy used head and haynes manual to line up timming belt. another car will cost alot and no guaranty that it will last
SHould I Keep Cb after this?
Originally posted by keycb7 View PostGet used head from J/Y for around $300 or less, practice on your blown one, just take off and put beck on, if you can do that than go and buy used head and haynes manual to line up timming belt. another car will cost alot and no guaranty that it will last
Originally posted by rodriguezyadir View Postyea .....man don't keep the car if it is fuckin up
fix it right and it will keep on tickin'
Originally posted by smoovewun View Posttiming belt went out the other day and didnt make a single sound...jus died on me....mechanic checked it said it was gone plus the head is damaged...anyway its gonna be around 900$ to fix should i keep it or jus get another car.....and dont say swap lol i cant really afford that funds are very low...but i want a h22 bad o well might as well jus buy another right?
i had this scenario with a friend and his mechanic once where he tried to tell him that.. in his case it ended up being the coil in the diz. ended up being alittle cheaper than the 1600 bucks he quoted lol.
heres the things i would do first:
1. take the tbelt housing off and check it... see how bad it is.
2. replace and re-time engine with a used belt from somewhere... cuz if the engine is screwed, you dont want to waste money on a new one yet.
3. crank the motor over by hand first from tdc to tdc, this well give you an idea if there's anything interfering with the pistons or broken inside the motor before you actually start it.
4. unplug ecu fuse and crank it over for about 2-3 seconds, if it sounds like a typical honda motor cranking, or sound like it did before this whole ordeal the you might be in luck..
5. next you can either do a compression test or you can just throw the fuse back in and see if it runs. if it does, then purchase a new belt and put it on.. remember to tdc everything before doing so. put tbelt housing back on and all. yer good to go.
those are the steps i would take before assuming its totally botched. if for some reason it sounds like it has comp but doesn't start, then do a compression test... if its good and still nothing then its something else in the car... electrical or fuel related.
if your planning on getting rid of the car, its already broken... so ya don't need to put it back together if its royaly screwed lol. and well ya learn a little something out of it.
just my .02cents
chris vLast edited by cvandulken; 11-29-2008, 01:10 PM.
Its your decision- don't let a bunch of intarweb people make up your mind for you.Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
2008 Ford Escape XLT [bone stock]
2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
