This may eventually change or whatever, but after much random discussion with Nic (90cb7sleeper) over the past few days and such I think instead of just refreshing my H22A before putting it in to go all out and create an H23/VTEC to have lots of torque matched with high compression. This means more time with the F22 but overall I think it I will be better off.
At this point in time I only physically have a full H22A. I can get F22 rods and crank very easily.
So without further adieu the proposed parts list:
H22A block
F22 Rods
F22 Crank, balanced and micropolished
Nippon Racing 87 mm P5P-J0 pistons *see below for random piston info*
H22A head, slightly ported and polished
Stock H22 Fuel injectors
Main studs and rod bolts
ARP head studs
Honda main and rod bearings, or possibly ACL
Intake manifold and exhaust options will probably be decided later, although I have ideas now
Piston info:
I plan on using Nippon Racing P5P-J0 pistons which are Prelude Type-S pistons, they will provide for higher compression. But you might be wondering why 87 mm and not boring over. Well, my block is marked BBBB which means my cylinder bores from the factory are between 87.000-87.010 mm and my stock pistons are also BBBB which means they are between 86.980-86.993 mm. So they are slightly less than 87 mm. To use a 87 mm piston I would have to have the block bored/honed ever so slightly to make sure piston to cylinder clearances are within the 0.007-0.030 mm spec.
H22A block
F22 Rods
ARP head studs
Piston info:
