is the EGR block off plate good to buy for turbo motor. i ask cuz i had a friend tell me i should get one and he is not a honda guy. i also seen them oy ebay
EGR block off plate
Originally posted by PR CB7Take A Look At It Dis Way
And Egr
Is An Exhaust Gas Recirculation Sensor
It Work At Low Rpms And I Think At Idle
It Takes Exhaust Gases And Injects Them Into The Intake
For Emissions
So U Decide
I blocked the EGR off on my Nissan 240 and didnt have no problems better throttle response as well Dont need a re-chipped computer if you dont have a valve or it is not plugged it it will just throw a light but wont effect driveability
Originally posted by 3tcRobNot at Idle just at cruising Rpm to keep NoX gases down and such doesnt work at full load either
IM pretty sure if he is boosted he is chipped which usually will eliminate the EGR.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
Originally posted by 93cb7accordi em boosted. i also got a p06 that im going to get chipped
egr is an emissions system, not an essential system.
If you're on a stock ECU which I doubt you are, but if you are then all you do is put down an EGR gasket, then the block off plate, then put the EGR back on. Don't disconnect it. The vavle in the EGR will still function so the ECU will think it's working but no gas will go through because the plate is there. I bought a plate for $20 shipped and never used it. I'd be happy to resell it to you at the same price if you're interested.
