build up of JDM F20B DOHC VTEC
    so i want to start an all motor build up of my F20B, my goal is to get somewhere around 200-220whp by summer. then possibly add some nitrous, but who knows...so anyone with suggestions feel free!!
    i know a lot of the h22 parts swap over, but i know the valves dont!! this is from the ground up, from exhaust, to cam work..so everything is open for disscusion!!
    this thread will be used until summer time, when my goal will hopefully be met!!! thanks in advance!
    random pics throughout thread
    .:edit:. update and new pics on page 7
    .:edit:. TB and IM pics on page 8
    .:edit:. Header install on page 9
    .:edit:. Oil Catch Can and update on page 11
    .:edit:. first time at track results on page 13
    .:edit:. Second trip to the track on page 15
    .:edit:. Dyno numbers and video on page 20
    .:edit:. New track times on page 20
    3/14/09 - 192/154 on a Dyno Dynamics
    Best time to date (3/13/09) on street tune: 14.37 @ 99mph w/ 2.3 sixty footer, in a 90 Accord Sedan
    Current 2016 Ford F150 XLT Sport
    Past 1990 Accord EX Sedan
    Past 1990 Accord LX Sedan
    Past 1991 Accord LX Sedan
    Past 1993 Accord LX Wagon
    Current 1991 Accord EX Wagon
    cant wait to see the dyno sheet that reads 220+ hp good luck eli
    PSN ID's:Tidashoni
    1992 Accord EX Coupe
    My FS Thread
    Not so DD 2013 Subaru Impreza WRX STI
    Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
      what engine management are u going to use? a complete AEM type setup or something simple like the Hondata ones?
      DEVOTE
      FS: Lokuputha's Stuff
        its running hondata right now, ill probably change it out though
          IF you are running to around 200-220 whp then Hondata will suffice. What do you have the s200?
          The New-ish Ride
          My old Ride
          Hear my Vtak!!!
          MK3 Member #3
          I piss off people for fun.
          IA 08 Sunburn Victim #1
            i think he has the s100 unit. thing is, he doesnt have the software.
            Eli, you should buy the software and I can tune for you.
            anyways, ask Juan about any shops around oregon or you may have to send out your head to a reputable shop.
            to start, I'd say some cams to open up that long power band, then some exhaust work to compliment it.
              yes, you can tune for me indeed, should i wait until i have more mods? or tune now?? why would i want to send my head out?? so i can have the h22 valves fit??? also, do you mean cam gear? cam shaft??
              should i go straight to that before i add bolt ons? wont i need to get it tuned right after i do cam work??
                yea dude, you dont need new valves. if anything, just get oem valves and then get a valve job done.
                i meant cam shafts. and no, you dont HAVE to get it tuned, but it would be very wise to do so. especially if you get very aggressive cams.
                oh, btw, over sized valves should be the last thing on your mind as they wont really help much with low hp.
                get head work, camshafts, throttle body, intake mani or itb's, exhaust work, and tuning. if you want, get higher compression.
                  Its not running the s100 unit because it wasnt running right, i had to burn a map with uber data to run it.
                  I heard that shop over at EL auto parts does a good job, alot of those hot rodder guys go there. last time i wanted to get my head done the guy said 350.
                  I think we should use Uber or chrome. I plan on buying a wideband some time after i sell my wheels.
                    and I plan on buying crome pro. its comparable to hondata
                      neptune ftw bitches juan didn't you say eli is running the map i played with and am running? joser found me a crome map that looks pretty good i'll be playing with soon too
                      Retired 1990 Accord LX Coupe
                      Project 240SX
                      Originally posted by chillin943
                      anyone kno if i can just make a hot wire for v-tec off the horn??
                      Vouches: Bought from: smseagren83, phatdoughnut, uk - accord, lucid, iamnemo, accord_inspire, 2point6, chopstickz, djcaz_aom, rosko
                        its actually uberdata dude. I opened it up the other day and it didnt look like anything normal. so then i opened it up with uber and bam, it looks good.
                        anyways, neptune doesnt have rtp according to 2point6, so ill be going with crome pro. its cheaper anyways, lol
                          weird i found one in the crome section and it opened up fine and looked right...neptune does have rtp, it's just not turned on yet, they are working on the final software patch which enables it
                          Project 240SX
                            what throttle body and intake mani should i be using?? for all my cam stuff, im thinking about using the h22 skunk2 stage 2 stuff, all of it should fit (cam gears, cam shaft, retainers, springs) right??
                            i still need to figure out why my idle is bouncing so much, it bounces from 200 to 3000 at random times....
                              clean out your fiv and iacv. cmon eli, search damnit!
