Hello. While changing the oil pan gasket I noticed some oil seeping from the black plastic timing cover right behind the crankshaft pulley. I assume this could be the the crankshaft seal, would this be correct? Is it a big job? Can anyone give me some advice on accessing and changing it. Thanks.
oil leak coming from bottom of timing cover on 93 accord
More then likely it’s either the front main seal or from your balance shaft seals. It is a decent size job as you have to pull off the timing belt and timing gear to gain access to any of those seals.
So it’s pretty much the same amount of work as if you were changing the timing belt. If your going to replace it might as well replace everything while your in there. Depending on how old the belt and water pump is.~Nick~
Here is a link to the engine DIY section. There are a number of threads on timing belt replacement that should also address crank seal replacement.
http://www.cb7tuner.com/vbb/showthread.php?t=20767790 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostHere is a link to the engine DIY section. There are a number of threads on timing belt replacement that should also address crank seal replacement.
