The title is wrong... It is a 1991, with those stupid seat belts!!!!
Well, First post, so here goes.
I have worked on my own cars all my life and I hate electrical problems the most.
I had my '91 Accord stored for about a year while traveling for work. When I went to resume it's use I knew it would need a new battery so I installed one.
After about 3 days the new battery was dead, so I removed it, charged it had it tested (it was good) and reinstalled it. I purposely did not drive it for a few days and sure enough it was dead again. So, the battle has begun...
This ain't my first rodeo, so I started with the basics.
-I pulled the negative battery cable and put a digital ammeter in series between the post and battery clamp. It shows about 170-200 milliamp drain. Certainly enough to drop the battery below 11.5 volts in 3 days.
- I started with the under hood fuse box and with no lights on of any kind (checked dome and trunk light by looking through the back seat into the trunk) I pulled the fuses one at a time.
-The drain drops to 20 milliamps, which I assume to be the clock and memory save in the (small Alpine stereo) when I pull the Passive (Seat Belt) motor fuse, either one (I believe).
I'm looking for ideas. This car came with the very nice Honda factory manuals (Service and Electrical). So I have documentation and determination.
Thanks in advance for any help or wild ideas.
- I have lubed the seat belt tracks from the B pillar to the forward stop in case the runner was not fully hitting the stop limit switch (a long shot I know but it's good maintenance.
- I replaced the drivers side lap belt retractor because it needed it and being in such a poor state I hoped it might help.
- I purchased a used but clean seat belt control unit (the one under the passenger seat), still no effect.
