Would my car be way slower if i swapped my F22a1 into a D16 or a D15? im just wondering because my F22 has blown rings and im on a tight budget and i can get a mini me for hella cheap.
F22a1 into D16
Firstoff , its gonna be slower. I dont think our mounts even line up.
You will be better off buying a replacement motor which you can grab for cheap at the yard
By the time all said and done fitting that wimpy d series engine in the car you have boosted the f motor(with all the labor that will need to be put in.
D16Y8 would be better...It has 20 more horses and 5 ft-lbs more tq than the Y7......lol
Edit:
Probably easier to get the Y8 up here in Canada. So the Y7 would probably be a more viable option.
Ether way a Full H22 swap and tune would be cheaper!Last edited by GhostAccord; 06-23-2013, 09:41 PM.
Originally posted by deevergote View PostA simple D16Y7 will move the car just fine. It's not much weaker than the F18A.
It's a weak engine for all the work it would take to install it, but the CB7 is not "too heavy" for it. It would work well enough.
Originally posted by 1993 CB7 LX View Postthen why wont a b series work?
A 200hp / 130ft-lb B18C5 from an ITR would still be a 200hp / 130ft-lb B18C5 if you put it into an Accord.......Last edited by GhostAccord; 06-23-2013, 11:13 PM.
