Greetings, I have recently done a JDM H22A swap into my cb9. I also happen to be one of the lucky ones to have the mysterious stumble on acceleration problem. I followed the writeup on a website called accordinglydone, and then doing alot of research on alldata and the internet to this problem. It will stumble on acceleration most noticeably for me at around 2300-3000 rpm. The motor revs and runs fine otherwise. The problem also only happens after the engine is warm. It feels to me like a fuel or an ignition issue, but have found a few other suggestions that make sense to me to this problem; including the tps, or main relay. I know others have had this same issue, or similar issue, and was wondering if anyone has found the problem? A few other things that might cause this are the fuel injectors or the spark plug wires, and will try those first. I am very determined to find this mysterious bug on jdm h22s and will stop at nothing. Any help would be much appreciated.
Solving H22A Stumbling
when my H was stumbling, it was related to the connections on the ignitor unit inside the distributor. The wires weren't crimped hard enough, or there was some oxidation from it probably sitting for a long period of time on the leads.
What I did to solve it was put dielectric grease on all the contact points for a better connection.
But when I FIRST got my engine swapped in, I had 3 prelude injectors and 1 accord injector in the fuel rail. There was a noticeable lurch when I first started the car. So just make sure, especially if you got your engine used like I did from some random guy.
member's ride thread
91 Accord SE 176k
I got my motor and ECU shipped from a company called Total JDM or Toronto JDM and I know how the weather can get up there. Theres also no telling how long it sat inside or out as I only got it a year ago. Those leads on the ignitor unit may very well be the issue and I'll check it out tomorrow. The injectors were also a culprit for me as Ive read that the h22a motor has two different cc impedence injectors depending on the year. I will check the part numbers on the injectors. I think they are supposed to be 345 cc injectors. Ill keep posting what I find. Thanks.
I had the motor and ECU ssshipped from them, not chipped. I am running a p13 stock ecu. I did a check of the wires and terminals going to the ignitor unit, and found that they were clean. They were also tight and I put dielectric grease on all of them. I also pulled my spark plugs and wires and made sure they were clean and tight. I also checked the fuel injectors which were 345cc injectors. Then I went to chevron and got a bottle of techron fuel system cleaner and then filled the tank. I also tried unplugging the 02 sensor but no difference. Anyways, after all this, on the way home it did stumble again slightly(before gas up). After the gas I have felt no stumbling yet, only time will tell. Any more ideas?
I also posted some pics of my ride in the gallery, check it out!
wait wait, im having this exact problem now. I could tell my motor sat for a LONG time as the grease points in the trans werent greased at all...It stumbles and chokes between 2-3 like yours. Running the stock p13. I didnt check my o2 sensor, my dist is new and in good shape i usedd. I was about to replace my main relay and everything, but your telling me i should check my injectors???91 LX Coupe H22 swap, n/a build in progress. "007 CB7"
I'll smoke your v8 like I smoke my ganja
sorry, techron fuel system cleaner? i just did the filter, about to do the rlay before i went ahead and did the pump. i know its gota be something stupid fuck the idle hunting this is whats pissin me off the most91 LX Coupe H22 swap, n/a build in progress. "007 CB7"
Sorry, that fuel system cleaner did not fix my problem. It helped for a few days, but now problem is back. Im starting to think o2 sensor or clogged EGR ports. Any other suggestions? I have had this problem for over a year!@! I am also throwing a code 12, which is EGR function code. So I will try cleaning the ports first, as I have already replaced my 02.Last edited by WagonLX; 04-21-2010, 07:02 PM.
If you have a code 12, cleaning the ports will not clear the code. Make sure the vacuum lines are properly hooked up, along with the electrical connections, if not swap the egr valve out for another one say from the junkyard. Then remember to reset the ecu by pulling the radio/backup fuse and/or disconnecting the battery.
It very well could be an o2 sensor problem if the car is stumbling. If you want to test whether its the o2 sensor causing it, simply unplug the o2 sensor, your ecu will throw a code and the car will start running of the basemap, then try driving around with the o2 sensor unplugged and see if the stumbling problem goes away. If it goes away then replace your o2 sensor to a Denso or NGK/NTK.
I just swapped internals from the different dizzys and now the car will not start. I am getting spark from the external coil and from the plug wires, but no motor action. Is there something I missed? Are these actually interchangeable with computers? in other words, did the jdm preludes come with external coil? stock p13 ecuLast edited by WagonLX; 04-21-2010, 09:13 PM.
now I have swapped the internals back and the car runs. I will try driving around for a few days with the 02 unplugged. I really dont like the light though, LOL. Then I will determine if I need EGR valve or not. I thought about it and remember unplugging the vacuum going to the EGR, thinking I had a vacuum leak at diaphragm, and I never cleared the codes. Thanx for the feedback, every little bit gets me one step closer to really enjoying this car.
