Old 11-22-2018, 10:41 PM   #1
boulky12
Newcomer
boulky12 is cool... so far.
Car randomly died, Cranks but won't start.
Really could use some help and advice. My daily has been down since Tuesday. It's a 93 EX Auto Coupe
I bought this car for real cheap and have replaced all kinds of parts on it and it's been running in tip top shape for a while.
I did have a similar issue like this about 4 months ago, pretty much same symptoms, I replaced the Distributor and I was good to go! Until recently..
Drove the car to work and back no problems at all. Went for a beer run shortly after arriving home.
Made it to the gas station. Got the beer and myself back in the car. And I suppose it was here that whatever failed, had failed.
Started up the car like normal, put it in reverse, moved 2 feet, Dies.
Started up again, this time hesitated to start, and took more cranks. Put it in Reverse, moved 2 feet, Died again.
Started up again, more hesitation, more cranks than usual, this time I tried to manually keeps the rpms up just so I could make it home down the street. Slammed it in gear, took off down the street for a 1/4 mile until I had to stop for a stop sign. While stopped at the stop sign, It Died..
At this point, I had to mash the gas several times or even hold it all the way for it to start.
It was dying and barely starting several times while at the stop sign.
I went ahead and tried to slam it in gear again and make it across the intersection, but of course, it died right in the middle of the intersection lol.
At this point, it will not start anymore, just crank and crank.
Pushed it off the road, popped the hood, didn't see anything obvious, I let it cool down for a minute, Tried to start and just cranks. Had to get my dad to help me flat tow home.
Last couple days I've tried - New distributor, checked all fuses, battery connections tight and clean, grounds are tight, Ohm test on coil checks out, You can hear the fuel pump, Main Relay is clicking like normal, I actually removed the 12mm bolt at the end of the Driver side Fuel rail, A whole lot of fuel came out with the key forward, so I don't think its a fuel issue.
I'm not getting any codes other than EGR.
I'm really stumped because I'm not getting spark even with a new distributor and a coil that's giving good ohm readings.
I think that's all Ive tried so far. Sorry about the long post. Just wanted to be very clear on how the car acted up to the point its at now. Really need to get her back on the road so I appreciate any advice. Thanks
boulky12 is offline   Reply With Quote
Old 11-23-2018, 08:00 AM   #2
Raf99
Gold Member
"not getting spark"....well you're close. Do you know if the igniter was replaced in the distributor?
Old 11-23-2018, 09:44 AM   #3
fleetw00d
Contributing Member
Along with Raf99's question, was it a new distributor (from where?) or a different used one? Did you actually check at the plugs for spark? Did you check the injector resistor? Could also be the ECU (although I think my bad ECU resulted in no fuel).
__________________
90 LX 4dr 5 spd 385,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 192,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
07 Element EX AWD AT (2) 87,000 - MRT: www.cb7tuner.com/vbb/showthread.php?t=211920
LOTS of CB7 parts - ENTIRE COLLECTION - FREE
Come and get it.
http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 11-23-2018, 10:59 AM   #4
boulky12
Newcomer
Quote:
Quote:
Thank you guys for replying!
I believe the Ignitor was replaced. I bought the unit new from Autozone. It was $40 without cap and rotor, so I thought I'd give it a shot. All components inside of it look new.
I did check for spark at the plug. I tried only 1. Guess I could try another.
I tried to do a quick search for how to check the injector resistor box, but couldn't really find any procedure. Can you please elaborate on this
Old 11-23-2018, 01:08 PM   #5
Grumpys93
Contributing Member
Eric the car guy has a great breakdown on how to troubleshoot
https://m.youtube.com/watch?v=9K78XIhhjAQ
__________________
~Nick~
Old 11-23-2018, 08:32 PM   #6
F22Chris
CB7tuner Member
F22Chris is very helpful F22Chris is very helpful
Why are you asking about injector testing? You need to fix a no spark issue, man. How are you testing for spark? Is there carbon trailing on your wires? Did you use a spark tester with a ridiculously large gap?
__________________
F22Chris is offline   Reply With Quote
Old 11-24-2018, 09:38 AM   #7
boulky12
Newcomer
Thank you. Good video. I did try to ground the coil like he did. And I did get a spark! I have yet to do the Ignitor test he showed. I'm going to try that one when we get back from this mini bike racing event
Quote:
I was asking about it because it was mentioned earlier. But you're right I should be focusing more on why I don't have spark at the plugs.
I'm pulling the plugs, Clicking them back on the wire, and grounding out on the exhaust shield. Scratched a spot with some sandpaper. I'm not holding the plugs with too far of a gap to ground. I actually had it pretty close and still nothing.
I tried cyl 1 and 4 again this morning. Still nothing
I've never heard of carbon trailing on the wires? How does that happen? They look pretty normal
Old 11-25-2018, 01:08 PM   #8
boulky12
Newcomer
I tried the ignitor test from the video.
Got a test light. Put one end on + battery post, other end on the Black/white wire on the connector at the coil. I saw in another thread that this is the Ignitor output (technically ground or negative controlled by the ECU. I believe this is the correct wire to be testing.
So my results were that my test light was blinking. According to ErictheCarGuy, that indicates the ignitor is good and probably a bad coil. But my ohm test shows I have a good coil?
I'm thinking about hitting up the Pick n pull today before they close and grabbing a few coils to see if I can get this thing started again. I saw they had them only $10 each. Autozone is like $50.
If that dosen't do it.. I might just have to find another Cb and use this one for parts cuz she's starting to make me maadd
Old 11-25-2018, 04:09 PM   #9
F22Chris
CB7tuner Member
No reason to scrap a car for a faulty ignition part.
Fleetwood suggested checking injector pulse to see if the computer is seeing crank signals, so that would be a good step. (Didn’t read all the posts, sorry Fleetwood I wasn’t trying to negate your suggestion)
Sounds like a shorted coil though so you’re on a good path. Make sure you get a coil from a 92-93. 90-91 are different.
Did you test primary and secondary coils?
__________________
Old 11-25-2018, 05:12 PM   #10
boulky12
Newcomer
I tried another coil from the junkyard. Passed the ohm test also. Still wont start
I am testing the Primary and Secondary. On primary I'm getting .6 -.7. On secondary 17.5 Kohms.
I tried cleaning the ground at the T-stat housing. Still nothing..
Old 11-25-2018, 11:03 PM   #11
F22Chris
CB7tuner Member
This says coil is okay... did you check wire resistance? Anything that meters over around 25k ohms at this wire length should be replaced, and if any read OL they’re broken.
Does your replacement distributor have a lifetime warranty?
__________________
Old 11-26-2018, 09:03 AM   #12
4GAccordH22
CB7tuner Member
4GAccordH22 is cool... so far.
Send a message via ICQ to 4GAccordH22 Send a message via AIM to 4GAccordH22 Send a message via Yahoo to 4GAccordH22
When you replaced the distributor did you replace the cap and rotor as well?
__________________
Quote:
Originally Posted by Junior Smurff View Post
4GAccordH22 is offline   Reply With Quote
Old 11-26-2018, 02:23 PM   #13
boulky12
Newcomer
I have not checked the wire resistance yet but I will once I get home from work. Thanks
The replacement distributor from Autozone does have a 1 year warranty. I been thinking if I cant figure anything out I'll take it back up there and try to get another cause it might have a bad ignitor.
Quote:
The distributor I bought from Autozone came without cap and rotor for 40 bucks. So I went ahead and just used my old cap and rotor. And those are only 4 or 5 months old.
Do you think its worth a shot to buy another cap and rotor?
The metal piece on the edge of the rotor did look a little brownish, but usually this is normal right?
Old 11-26-2018, 11:10 PM   #14
Grumpys93
Contributing Member
If you coil is good and your igniter is good then the only thing standing in between that and the spark plugs are the wires, distributor cap, and rotor. might be worth a try and if it doesn't work return the cap and rotor.
__________________
~Nick~
Old 11-27-2018, 08:59 AM   #15
4GAccordH22
CB7tuner Member
You said you had spark at the coil but not at the plugs. That likely means either the cap/rotor or the wires.
__________________
Old 11-27-2018, 07:55 PM   #16
boulky12
Newcomer
So to make sure it was something in the distributor I had my buddy Edgar (dreamability) borrow me his spare dizzy. Thank you bro
Slapped it on after work and she fired right up!
Went to vatozone to get a cap and rotor, installed it on my old dizzy, installed the dizzy, fired right up!
Man I feel stupid!! All this because of a $15 cap and rotor!!
Really didn't think it was this all along because like I said, the old ones were only 4-5 months old. And the way the car just stopped starting, I didn't know they could just fail like that. Lesson learned!!
Thank you all for your help. I really appreciate it.
Excited to be driving her to work again in the morning
And I look forward to installing the Tein Street advance's that just arrived for her, this weekend
Old 11-27-2018, 09:55 PM   #17
F22Chris
CB7tuner Member
Can you show us pics of your old cap and rotor?
Edit: I’m just curious to see what the failure mode was.
__________________
Old 11-29-2018, 12:39 PM   #18
boulky12
Newcomer
Here are the bad cap and rotor. I think the rotor took most of the hit.
Old 11-29-2018, 12:57 PM   #19
Grumpys93
Contributing Member
That rotor looks burnt bad. Like some arcing was going on.
__________________
~Nick~
Old 11-29-2018, 03:24 PM   #20
boulky12
Newcomer
That sounds about right
