You can just change it and add more coolant if you want to. There are 2 or 3 actual heater hoses, so be careful which one you get. Yours goes to the heater control valve from the head. There is another one that goes from the valve to the heater, and another from the heater back to the engine. They are all shaped differently. Good luck
one of my hoses is sliced.
If I were you I would check all the hoses and possibly change them all.. I mean hoses aren't that much all the like hoses just measure how long it is for all of them go to autozone and get a hose long enough to cut all the hoses with. That's what I had to do
Originally posted by Juice21thnx pimpette, your car inspired me to go lowerOriginally posted by GameChewerShiit i heard that, you heard the queen!
Originally posted by Tom View PostIt looks like your bypass hose. I just replaced mine this weekend. I went to AutoZone and it was a special order. The guy let me behind that counter and I was able to match it up to a similar one. It only cost 7 bucks. It was kind of a pain to replace because it's hard to get to and it has those stupid clamps on it. When I put mine on, I put the other hose clamps with the adjuster screws on them.
Unless it running to the fire wall, then its probably a heater hose like Frostcb724 said
I did mine last week too, and yes it was a bitch to put on, i didn't replace the clamps, i was able to out them on after 30 minutes fighting.
well its all fixed got the new hose. my hose actually wasnt sliced it was blown. but either way new hose. and hell yes those clamps were a bitch. i changed them over to screw on clamps way easier to undo. and finally after 4 days i get to drive my cb its a miraculous day. thanks for all your guys' help.
