cp[mike] : 1992 Accord EX
    Sweet. That is pretty steep I can tell. Usually if I am working on my car in the garage, I leave the ass hanging out to leave more room. Then I need to get it in and close the garage I push myself and use a baseball glove to chock the back wheel when I move to pull the parking brake.
    Oh and, put some air in the tires on the grey one.
    Gary A.K.A. Carter
    [sig killed by photobucket]
      Originally posted by cp[mike]
      i like to play with my bitch
      sorry to hear about the car mike....but its nutttin u cant handle
      My Members Ride Thread
        i took the head off tonight. it took 4 hours and it was FREEZING COLD out there. my hands were numb most of the time. anyway nothing looks visibly damaged, yet the motor had barely any compression. timing was still all straight, so nothing happened to the belt. going to drop the head off at the machine shop so he can double check, then ill be ordering a replacement set of valves :\
        before i started
        ugh, salt
        disassembling
        3 pairs of pants, 4 shirts, coveralls, 3 pairs of socks, hat and gloves. it was cold!!!
        it was 23° out there in the garage!! my kerosene heater is broken, i need to replace the wick tomorrow.
        working
        heads ready to come off!
        hmmmm
        nothing is visibly bent or damaged...
        not very many bolts/parts needed to be taken apart to pull the head off.
          danm mike your my hero seriously man you dont fuck around! i give you mad props for working in the cold too i know how it is you just want to get the shit over with. ive never seen someone work so fast and precise though. i rmeember when you replaced a headgasket over night and i was like WTF? gj though
            There are a lot of times that the valves won't look bent...
            That is one of the things that sucks when they get bent just a little bit...
            Good to see it is moving along, sorry to hear that you had to do that in the cold garage.
              yeah, last time they didnt look bent either, but once i stood them all up next to each other on a table, you can see a couple of the stems were slightly angled compared to the other ones. i guess ill see soon enough as far as these go...
                dropped the head off at the shop today. the intake valves are perfect, the exhaust ones are in question... hes pulling them out to measure them, then ill be ordering a few new valves. fortunately it wont cost as much as it did last time
                  mike... i think you should be the new mascot
                  To see my car click here
                  Bordeaux Red Crew #8
                    Nooooo. if you need a hand with anything call me up.
                    .............................-----------------93 Ex Coupe[/COLOR]-----------------
                    My CD7
                      at least you had shelter from the wind, if i wanna work on my car i gotta do it out in the wind. good luck with the head tho.
                      -sean
                      Members ride 15.927 @ 86.76 (f22a1)
                      Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
                      Arcadia Green Crew #10
                        super high resolution picture. i doubt ill ever be able to get it as clean as it was when i first finished, so this is probably the "best" picture ill ever get of it.
                          hella fresh....
                          Cali.Dumps.Harder.
                            so is it done yet?
                            I see youve devoted the most time this one than the others mike haha
                            Henry R
                            Koni/Neuspeed
                            1992 Accord LX R.I.P
                            1993 Accord EX OG since 'o3
                            Legend FSM
                              ^^^been my desktop background for the past two weeks.
                                Mike sorry to hear that your valves were bent.. I hope everything works out. It always does for you.
                                "click the picture for members thread"
