Old 04-02-2018, 11:03 AM   #1
DipeshN
Newcomer
DipeshN is cool... so far.
Exclamation Roh Uk Setup Help
Okay guys I had been askng around for a while if a set of bb4 prelude front nuckles would work for a ROH setup well on the weekend i found out it didnt...
as my car has ABS and the other prelude knuckles didnt so im kinda stuck on what parts i actually needed as You guys in the USA have a huge option where as us in the UK dont.
I was trying to upgrade my front arms with rotors and calipers but there was no ABS slot and mountings on the actual leg where as our accords do.
Thanks please shine some light on this topic as ive just thrown some stupid amount of money at it so far
and all the other threads have dead images before you tell me to use the search bar because i have used it.
thanks
DipeshN is offline   Reply With Quote
Old 04-02-2018, 10:18 PM   #2
92smokeaccord
CB7tuner Member
92smokeaccord seems to have made some friends! 92smokeaccord seems to have made some friends!
I believe the absolute easiest way for you to do a hub over rotor in the uk would be to get just the wheel hubs and bearings from a 95 oddesy or what ever is the uk equivalent van. They legit bolt into your stock cb arms and you can use the prelude rotors and calipers with brackets. Doing this will retain the abs sensor. Iím really not sure What else you can do. There is how ever in the us a Acura cl that is rotor over hub but I am unsure if it has abs or not.
__________________
my new turbo build
92smokeaccord is offline   Reply With Quote
Old 04-02-2018, 11:01 PM   #3
Jarrett
Contributing Member
The Honda Odyssey is a 5-lug. That adds a whole new layer of complexity for someone not wanting to change anything besides the hubs and rotors.
The '98-'99 2.3CL has the hubs you want. I know they're not available there, but they show up for sale quite often. We don't allow sales here on the site until a user has established themselves by obtaining 30 posts, but there are other places, such as some of the Facebook classifieds groups, where you can find them for sale.
The '98-'02 Accord 4-cylinder Accord could be an option if you wanted to grab the entire knuckle, but you would need access to a lathe to turn down the back side of the hub where the axle slides in. There is a protuberance there that prevents the axle from seating against the hub perfectly. Odd, because it's doesn't appear in the V6 cars of the same body.
__________________
Old 04-04-2018, 07:05 AM   #4
marcusv8thunder
CB7tuner Member
marcusv8thunder is cool... so far.
Where you based in UK?
As Jarrett says, get those 98 99 2.3cl Acura hubs. That what I did. Then get new cb bearings and press them on. I run bb4 calipers, caliper brackets, pads and discs. You might find the disc location screw doesn't line up but that doesn't matter.
__________________
UKDM 93 CB3 Page (1) H22A U2Q7 LSD
UKDM 91 4ws Page (3) OEM Minter
NOW H22A U2Q7 SWAPPED
marcusv8thunder is offline   Reply With Quote
Old 04-11-2018, 01:31 PM   #5
DipeshN
Newcomer
Thanks for the input guys! and yeah iwanna stay away from the 5 lug swap right now as i wanna just run my prelude bb4 disks and calipers as i have them here ad then possibly run the WerdWerx caliper kit at a later date as that should fit up once doing this upgrade...
sorry for late replies my phone doesnt tell me most of my emails D'oh!
Old 04-11-2018, 01:33 PM   #6
DipeshN
Newcomer
Im based in Birmingham in the midlands how about yourself?
oh okay where did you pick them up from?
also send me a pm would be nice knowing somone else in the uk owning a cb! and the upgrades they have done on thiers with local knowledge haha
but im guessing facebook or ebay would be my best bet to get those hubs
Old 04-11-2018, 04:22 PM   #7
marcusv8thunder
CB7tuner Member
This site is solid for all things cb. Alot of my cb knowledge and modifying has been becuase of here.
If you click my links below you can see my cb (s) ive done alot to them. But mine is childs play compared to some on here.
I will pm you now.
__________________
Tags
brakes , coupe , help pls , roh
