closeout deals at rockauto
    I just got an email from Rockauto (no affiliation) that they have a bunch of closeout parts that they just acquired and they are selling them cheap.
    https://www.rockauto.com/RSS/vehicle...arcode=1167162
    1993 Accord Lemons Race Car, "SpaceEx Starship"
    M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
    I took advantage of this. Thanks for the link. Got items I’ll have to replace eventually.
    ~Nick~
      Thanks for posting. I acquired 9 routine maintenance items for $26 shipped.
      And the discount code works too.
        this is actually a permanent link! add it to your favorites. the items will rotate, but it's always stuff on closeout, and always super cheap.
        they have the same type of URL for every car. If you can figure out your "car code" (hint: its in the address bar when you click the RSS button on their browser page) and insert it onto the end of the link posted by OP, you can find the closeout link for any vehicle:
        1990 Accord https://www.rockauto.com/RSS/vehicle...arcode=1167061
        1992 Accord https://www.rockauto.com/RSS/vehicle...arcode=1167162
        1995 Prelude https://www.rockauto.com/RSS/vehicle...arcode=1170144
          You're not having problems with Rock Auto? I try addresses in 3 cities I can use, and they refuse to ship to Colorado for me. It's been this way for a while.
          Accord Aero-R
            I can't get things shipped from rockauto to colorado. I wonder when this will end.
