Hello all,
new guy here. Wanted to say a big thank you for your community here and the wealth of knowledge gathered in one spot! awesome stuff
Now, my problem...
I have found many threads relating to this issue on here...IE replacing the capacitors and resisters. All good there, replaced them all.
One thing though is on the backside of the circuit board there were burn marks at most the caps and resisters locations but also one other component no one has mentioned on all of google...lol
It is the 3 conducter transistor at the Q4 location
my problem was that the values/marking, part numbers were just about non existant...but with many hours at a huge magnifying glass and LED lamps I made it out to be "B931" which by all my searches seems to be a
2SB931 P SL 130V 3A 30W transistor.
Can anyone tell me if they are familiar with this part, if that looks about right? or possibly able to look at your TCU and see if its marked clearly? I have not been able to get my hands on an official honda technical service manual or even just a schematic for the box.
If this is the right values, I have assumed it is, I have been scouring the local frys electronics, rat shacks etc with no luck what so ever.
Frys carries http://www.nteinc.com/ parts, but cant for the life of me cross reference and find the matching NTE part number.
did find one on ebay here http://www.ebay.com/itm/2SB931-P-SL-...item588502d3ff
and will order one here i guess
i guess after that mouthful my question is if I am correct in the part i am looking for...if anyone knows.
And i guess just how easy are these transisters to burn out? like if i can plug in a give it a shot since I have replaced all the leaky caps and shot resisters.
The transistor is just discolored at one of the soldor points, but otherwise looks fine. I know that doesnt really mean its good, but point being is its not physically fried like the R41 was
anyhow, mucho thanks guys and I will definately post back results and whatnot. I just praying that someones TCU is handy and have clearly marked numbers on that Q4
Oh and FWIW my TCU part number is 28100-PXO-721-M1
oh one more thing.... wondering if a 2SD1254 may work in place. It seems to have the same voltage, wattage and amp ratings....cant remember if PNP or NPN though..have to look
Now, my problem...
