Intermittent Starting issue
    Ive searched the forums but i havent found an issue like mine so help is appreciated. My 92 LX, manual has a problem starting sometimes. Doesnt matter if its cold or hot. I did notice that i did not hear the fuel pump when this happened so i changed it and it still does it. Im thinking ignition or main fuse but i wanted to get some feedback before i start throwing parts at it. Thanks in advance fellas and ladies.
    Procrastination is a THIEF of time!!
    MY MRT
    http://www.cb7tuner.com/vbb/showthread.php?t=203992
    My First CB7
    http://www.cardomain.com/ride/705233/1990-honda-accord/
    When it won't start and you do not hear the fuel pump prime when the key is turned to the ON or RUN position, it's almost always the main relay.
    If you do not want to waste money or throw parts at it you can remove your main relay, inspect it, and even repair it.
    http://www.cb7tuner.com/vbb/showthread.php?t=53888
    If you find that the relay is bad and opt not to repair it feel free to give me a PM and I can hook you up. I have about 40 main relays that I have pulled from the salvage yards around here and repaired then tested.
    On another note, what fuel pump did you get to replace your old one with?
      if you don't hear the fuel pump when it happens then your main relay can be at fault. Watch the CEL turn on when you turn on your key. If you hear a click from under the dash when the CEL turns off then your car should start.
      If you don't hear a click and your car doesn't start, then the main relay is the culprit.
      Retro!
      Hater
        Thanks, i actually picked up a relay from the JY so ill give it a try. I picked up an OEM off of ebay. I also did the cut out trick so i didnt have to remove the tank. it saved me hours. Only took about 45 minutes to change.
        http://www.ebay.com/itm/90-93-HONDA-...4dc201&vxp=mtr
        I appreciate the input
        MY MRT
        My First CB7
          Thanks man, ima give it a try tonight
          MY MRT
          My First CB7
