map sensor and fast idle?
    what happens if my engine runs whitout a map sensor and a fast idle...cuz i ain't got any on my h22...i didn't check that when i got my swap done
    My signature works perfectly fine.
    wait what? if you run without a map, your idle is going to be going up and down. without hitting the gas.
    miss my turbo cb7
    moved onto volvos. dont know how that happened, just did
      That don't sound too good
      Originally posted by Juice21
      thnx pimpette, your car inspired me to go lower
      Originally posted by GameChewer
      Shiit i heard that, you heard the queen!
        thx..gotta hit the junkyard
          Your car might not even start up without a MAP or take a long time if not run like crap as already mentioned. Why dont you have one on your stock accord??? That is my question. If its broken yea but why do you have to find one? Sounds like you dont have one in there.
          The New-ish Ride
          My old Ride
          Hear my Vtak!!!
          MK3 Member #3
          I piss off people for fun.
          IA 08 Sunburn Victim #1
            cant your car be tuned run properly without the MAP. kinda like how you can remove your IACV. im talking of course a H22A swap with an OBD-1 ECU.
            -1997 Acura 2.2CL 5MT (Frost White)-
            -JDM H22A Engine-M2A4 Trans
              nope. a map is manifold air pressure. taking it off, then reving up can do harm to the motor.
              miss my turbo cb7
