Is there really that much of a difference in performance between no name and brand name intakes?
ebay sri vs brand name sri
This has been covered EXTENSIVELY on this site since 2003.
A pipe is a pipe, especially when it comes to short ram intakes. If it fits, it will work the same as any other. The filter is the issue, though. A cheap filter won't work as well, and will likely allow dirt into your engine. A quality filter is necessary.
If you bothered searching for this topic at all, you'd have seen countless people being told "buy a cheap SRI and put a quality K&N, AEM, or Apexi filter on it".
Originally posted by h22sparkle View PostIf anything you can make one yourself.
I am the Yakuza CB7!JDM 96spec H22A 178HP 149TQ
"The JDM Fleet"
1993 Accord Sedan - 2.2 JDM H22a1994 Prelude V-Tec1999 CL 3.02000 Prelude2010 Accord Crosstour - 3.5
1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.51994 Mirage S Sedan - 1.5
1991 Isuzu Impulse RS - 1.6 AWD Turbo1993 Asuna - 1.8 "CDM Impulse XS"
1993 Sentra SE-R - 2.0 SR20de1995 200sx SE-R - 2.0 Sr20ve
i did the home depot . go look for pipeing the same size or a little bigger the throttle body . get some 20 , 40 ,90 degre bends or what you need to get it where you wont it . then run it to where your heart desires and tack weld on the way . once its the way you wont it then take it out and fully weld it. simple cheap and less then 50 bucks . just dont try to smog your car with it .Last edited by Accord problems; 09-25-2012, 12:29 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Or just use plastic piping and epoxy. The intake doesn't get very hot. Shit, you could use flexible ducting (people have done it...)
It's your car, man. Be creative. Just think carefully about every mod you do to determine a) if it'll actually be beneficial, b) if there is any way it could cause damage, and c) if doing something yourself is going to be comparable to paying money for a "real" part.
