door sign problem
    door sign problem
    ok so the door sign on the cluster on my cb7 doesnt work and even the interior light that lights up when a door is not closed properly doesnt work.it doesnt show if the door is open or not.
    can any 1 tell me what could be the problem?
    thanks
    My signature works perfectly fine.
    thanks
    sounds like a bad door jamb switch.
    Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
      Its the door switch problem. Look in your door-sill and theres a black thing that moves side to side held on by 2 screws. You probably have to get new ones or junkyard ones.
      The dome light and door switches are directly related.
        As stated already, it's more than likely a bad switch.
        Just for reference, I bought 3 switches from the JY for $10 all together.
        So, it definitely wouldn't hurt to try that.
          i took mine apart and cleaned it with wd-40. it worked fine after that. later.
          Avoiding dirt at all costs
            ^^^^^i did the same thing make sure u clean the metal contact points real good
              thx for the help guys..ill try to clean it up first if it doesnt work ill just get some from the junkyark.
