ECU question
    ECU question
    i just swapped a f22a6 in my girlfriend's car.
    does it make a difference if i use the ecu of the f22a6 or can i keep the f22a1 ecu?
    thanks.
    My signature works perfectly fine.
    if you used the a6 intake manifold and iab box youll need the pt6 which is the a6 ecu to control the iabs. it will run with the pt3 but you wont get all the power needed. the pt6 is the best option
      whats iab box?
        little black box with a vac connection that opens the iab butterflies on the a6 intake manifodl
          oh ok..ye i got the a6 intake..i'll change the ecu first thing in the morning.
          thanks alot.
