idle problem
    idle problem
    i dun know y but car always idle 1.4k and even sometime jump to 2k...it never goes below 1k...
    any suggestion how to fix it.... thx.
    My signature works perfectly fine.
    Now is this when its cold or when its warmed up?
    "form follows function."
    Louis Sullivan
      warm...and when its really warm it goes up to 2k..
        1. Clean your tb
        2. Check for vacuum leaks.
        If I left something out feel free to add.
        Louis Sullivan
          where is the idle screw located..oh and i already cleaned my tb
            Wait do cb even have those?? LOL! I havn't worked on a cb for so long. Scratch that!
            Did you check the tb gagsket?
            Louis Sullivan
              check wat on the tb gasket?
                The gasgket seal on the throttle body that mates up to the manifold.
                Louis Sullivan
                  ye everything seem normal...i cant locate the idle screw to adjuste it...it's a h22
                    Hahaha don't worry about the screw I was thinking Toyota instead of Honda.
                    When was the last time it ran without the rpm jumping around?
                    Louis Sullivan
                      I have the Same problem its just the Idle Air Controler. i have good friends that work at the AutoZone (soon i will to) and they all agree. it is a Special order part so be ready to spend some cash and wait a while
                        its been too long lol i dun remember.
                          yea i kinda have the same problem but mine wants to stay @ 1,500 RPM for a while then go down to 600~800RPMs.
                          we think its the Cold sensor(w/e its called) so yea i gotta get that fixed
                            clean tb
                            clean iacv
                            check for vacuum leaks
                            adjust idle screw the proper way
                            if still does it...adjust fitv
                            if still does it...well get to that when it happens
                            ____
                              Originally posted by bcjammerx
                              clean tb
                              clean iacv
                              where the the adjust screw located on a h22?
