Distributor
    I noticed no difference. USDM H22A ones are external coil, so unless you convert to external, they won't work for a JDM distributor.
    noticed no difference in what? The circiles on the h22 ones i have are much bigger.
    ANd what do you mean they wont work? They will, you just wont be able to use the coil wire.
    ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
    NE GUYS, Buy the last of my accord parts
      can the dizzy from a f22b1 be used on a f22a4
        no.
        Originally posted by kc8enb07
        does it come w/ jdm trash? they better throw away gold in it
          Different CB7 distributors
          I've noticed that some cb7's have slightly different distributors. Did honda make some sort of improvement to the distributors on the 92-93 accords or something? Also when I bought my ngk wires they came with a extra 5th wire, what's that for?
          H22 Fund Cancelled. Flight training underway.
            since your car seems to be a 90-91, your distributor is internal coil, and you have no use for that 5th wire.
            92-93 accords use it, because they have external coils
              Is there some advantage to that ghost? Like, will I get a longer cap/rotor life or better combustion if I were to use a 92 accord distributor?
                You are really just getting an external coil, which, like Deev said, is useful if you are looking for an aftermarket coil. It might be a little bit stronger, might not be.
                The cap also works on some Civic engines. For instance, I got a clear red MSD cap at Summit (I was in reno, at the store, so why not?), and it was listed for a 1.6/1.7L Civic motor.
                1992 Prelude S w/swapped H22A
