Distributor
    Distributor
    can f22a distributor can be used on the h22a???
    and if it can then does it make a diffrence if ur using a f22 distributor on h22.like performance wise or anything?
    My signature works perfectly fine.
    I believe they can if they both internally/externally coiled.
    wat?
      u can't use a f22 dizzy on a h22. it will not fit.
      Originally posted by kc8enb07
      does it come w/ jdm trash? they better throw away gold in it
        hm.. i wanted to change my cap and rotor on my h22 so i bought the cap n rotor for it but when i was installing it the cap wouldn't fit. so i bought the cap of f22 and it seems to fit on the distributor...so i am guessin that i have a f22 distributor on h22...
          The caps are interchangeable. Pretty much all hondas throughout the 90s used the same distributor cap. The only differences are the coil location.
          Gary A.K.A. Carter
          [sig killed by photobucket]
            AND bolt on locations
            pretty much all obd1 distributors are the same internally. Its the main housing that makes a difference.
            a f22 one WIL NOT FIT. h22 or h23 will.
            ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
            NE GUYS, Buy the last of my accord parts
              so basically my question would be can i use a cap and rotor of an f22 on a h22 distributor?
                Yes. I'm currently running a "90-91 Accord" cap and rotor.
                  thx for the info...first thing in the morning i'll change that.
                    oh and also...do i have to buy h22 plug wire or f22...or is the same thing?
                      the circles for the plugs on the valve cover are different sizes. a f22 one would work, but you wont get the water protection sealing you should be getting.
                      get the h22 one. The $10 you save on buying f22 ones is stupid.
                        thanks for for the info
                          I noticed no difference. USDM H22A ones are external coil, so unless you convert to external, they won't work for a JDM distributor.
                            so what so good about an external coil? is it any better than an internal one?
                              There are aftermarket options for external. I'm not aware of any aftermarket internal coil upgrades.
