Outer CV Joint with ABS - Repair
    Hi
    I have tried to search for the answer but could not find it.
    My axle is clicking when I turn left, this means my right Axle is the issue.
    More often than not it is the outer bearings that click and therefore need to replace the outer bearing.
    I have an automatic, sedan with original motor (F22A9) and transmission.
    My questions and options are:
    1) Using a complete CD accord axles.
    I believe they are not interchangeable but please confirm.
    2) Failing 1 above, my option is to repair my existing Axle.
    Is the outer bearings on the CD Accords axles the same?
    3) Failing 1 & 2 above my option is to use non ABS outer bearing and convert it to ABS.
    Are the ABS rings removal? If yes, good success rate without snapping?
    Any input would be appreciated.
    Rides:
    Accord
    92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
    96-AUDM-2.2 VTiS- Heather Mist
    CR-X
    88-JDM-Si- Black
    CR-X Del Sol
    92-JDM-SiR "Transtop" Motegi Edition - Silver
    95-JDM-SiR "Transtop" Daytona Edition - Silver
    92-JDM-SiR "Transtop" - Black
    Prelude
    91-JDM-Si-4ws "Si States" - Phoenix Red
    91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
    91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
    91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
    The reason for the above is I wish to stick to OEM parts.
    There are replacement outer bearing kits on Ebay and internet but most are aftermarket or by FEBEST.
    From my research and from first hand experience using their ball joint boot replacements, FEBEST is not the best. The rubbers break fairly quickly (6 months or less).
    I do not have much faith in their product or any aftermarket. I have been tricked on several parts that looked great new but are really not durable.
    Examples:
    After market front engine mount "Dog Bone" no name = broke in 3 months
    Upper control Arms from "Tas Auto" = bushing on one side deteriorated in 4 months.
    Ball joint boots "Febest" = torn in 6 months
    Purchased original front engine mount "Dog Bone" = still solid after 10 years.
    Purchase second hand upper control arms = still solid after 4 years.
    OEM Honda originals = lasts over 20 years easy. Like night and day, no comparison.
    Rides:
    Accord
    CR-X
    88-JDM-Si- Black
    CR-X Del Sol
    Prelude
      i like to use the honda part dealer's exploded diagrams to search for interchanges thatll work. download the factory service manual theres a lot of info there.
      https://www.hondaautomotiveparts.com...is--driveshaft
        Thank you for the reply and the website.
        Never knew of this website and access to the schematics with part numbers is helpful indeed.
        By the looks of it the CB and CD cv joint outer bearings are not the same since the part numbers differ.
        Also by the looks of the schematics the ABS tone rings are not removable since it is not being shown separately.
        If this is correct the outer bearings on the CB accords are unique and cannot be sourced off another model.
        That means I either wait for a CB wreck with ABS (which is rare and will never likely happen this year) or buy new (OEM or aftermarket). It seems buying new is looking to be the best option.
        Rides:
        Accord
        CR-X
        88-JDM-Si- Black
        CR-X Del Sol
        Prelude
