Whistling sound while accelerating, about half throttle, coming from engine bay.
    Getting a whistling sound coming from aftermarket cold air intake, or so I assume, happens while accelerating on about half throttle. Goes away when more throttle is applied. Thought it was the metal filter on the intake, changed the filter and noise is still present. 2 1/2” C.A.I. Solid about 1/16” to 1/8” aluminum pipe goes through into front fender behind fog light.
    Any idea if I’m hearing something different? Maybe coming from intake manifold or throttle body? Thanks
    pretty sure that's normal. check your vacuum lines to make sure you didn't leave any disconnected. later.
    Avoiding dirt at all costs
      How well are any joints (tube to filter, tube to throttle body) sealed? A small leak (weak vacuum because of the pressure drop through the filter) could tend to whistle.
        Normal. The reason most buy the intake is for the sound(s).
          The sound they're looking for is more of deep throated whoosh (to use a technical term - what I got when I cut 3 inch hole in the bottom of a stock air filter box) isn't it, not a whistle?
            Also look for collapsed vacuum lines like the one from the PVC to the intake manifold. They too can make whistling sounds.
              Sounds normal, my H22 does the same. I have also rode in two other B18Cs
              that make the same noise. It is from the intake.
              Keep Pushing..
                Thanks guys for the direction, it’s most definitely not a pleasant sound like a bassy “braaaaaâppp” (technical term) is like a whistle or a fast streaming/whirling ... what about coolant hose noise or water filter whirl? What do they sound like? P.s. that is a serious question lol
                  Need to post the complete link; it is abbreviated.
                    Well I ended up taking off throttle body because I know I did not have a gasket on it,to see if that was my issue, annnnnnnd threw on a skunk 2 throttle body which took some modifications to get to fit correctly with a my map sensor being in the emissions box I had modify that as well being as it’s not a throttle body mounted map. And I’m ashamed to say I used some 90 minute gasket maker to get a airtight seal on both. Here’s to tail tight seals and weekends working on the cb7
                      https://share.icloud.com/photos/0XNy...-_Hill_Section
                        You don't say specifically - did that stop the whistling?
                          Uhh I hope, had to recalibrate the tps and we all know the pain of working on Honda’s in general being that the engine bay is cluttered with hoses and wires and whatnot and I had to modify this skunk 2 TB, had to or at least think I had to use my oem throttle lever since there was only a slot for one cable and long story short I’m not sure..... got the throttle lever almost in a run able spot(idle to high) last night and going to/have to get it running today... but geez since I already had it in place and didn’t want to remove it once again it sure is hard to reach the set screw and nut on the throttle lever.... I’ll try to snap pics when I’m in the heat of battle to show you the work done and amount of space I’m working with. Wish me luck
