progressive pro tuners for accord?
    should i, or is anyone else getting one of these HONDA PILOT/RIDGELINE/S2000/ACCORD/PRELUDE PRO TUNER there on ebay http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
    I want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
    My Ride *****;http://viewmorepics.myspace.com/inde...lbumId=2844229*****
    Oja Thnx Everyone, at cb7tuner.com
    seems like a pretty good deal
    for 14$ with 9$ shipping, seems pretty cheap to me for a controllable A/F ratio. fuel map tuner
      All it does is intercept the signal from the IAT sensor, making the ECU think that the engine is taking in cooler air than it really is. At least from what I can gather. You'll be adjusting the fuel without actually adjusting the airflow.
      I agree, it's cheap... and it might do something... but I wouldn't mess with a gimmicky thing like that.
        Well..
        I do have a cold air intake/
          Yes, but with this thing, you're not actually changing the oxygen content of the air you're taking in... just making the ECU THINK that you did.
          It's oxygen that makes power in the engine. Fuel is basically there to act as a catalyst for ignition, and then to keep the burn controlled.
          This thing is at least more believable than the "power chips" you see on ebay, but I'm not so sure that it would work any better.
            WOW +22 horsepower gain. I highly doubt it! If that were the case it would be more known and sold by professional auto stores/web instead of a cheesy gimmick looking ebay site. I wouldn't buy
              whats funny is these things are usually tested on turbo vehicles because on a turbo vehicle with the IAC temp cooler the ecu will generally lean out the mixture and may run a bit more boost which is where they get that 22hp from. On a NA honda gains would be so minimal it would be a waste of money. You would probably gain more HP from a heatshield gasket and it would be better than trying to trick an ECU.
              member ride thread
              DIVULGE MOTORSPORTS
              John 10:18 "No one takes it from me, but I lay it down of my own accord. I have authority to lay it down and authority to take it up again. "
                sounds scary
                would never put something that sketchy in my car
                Viva la CB7!
                  it's a resistor. you can get one at radio shack for a dollar. it doesn't "tune" anything.
                    I wouldn't mess with that thing man. Looks like it's screaming for problems to come up.
