Night Wolf : 2005 Subaru Impreza WRX
    Yup a non-Honda. My newest ride, a 2005 Subaru WRX Premium Package...
    >>>Link for more info on these cars<<<
    >>>MOTOR & GEARBOX<<<
    123,000 Chassis Miles
    NEW EJ257 Block
    ACL High Performance Rod/Crank Bearings
    NEW Forged/Blue Printed EJ257 Crankshaft
    Manley H-Beam Connecting Rods
    CP Forged Pistons
    High Performance Piston Rings
    Polyurethane Shifter Bushings
    STI Rear Differential
    STI CV Axles
    STI Drive Shaft
    Optional Rear Differential Shield
    Tial Q 50mm Blow Off Valve w/11psi Spring
    Competition Clutch Stage 5 STI Clutch kit w/4 Puck Disk
    Perrin 3in Cold Air Intake
    Perrin Radiator Over Flow Tank
    Injector Dynamics 2000cc Fuel Injectors
    Teal Valve Covers
    NEW STI Oil Pan
    NEW STI Oil Pump
    NEW Oil Dip Stick
    Cometic Head Gasket
    ARP Head Bolts
    Group-N Engine/Transmission Mounts
    Gates Racing Blue Timing Belt
    Killer-B Oil Pickup Tube
    Brian Crower Adjustable Cam Gears
    Brian Crower Stage 3 280 Cam Shafts
    Brian Crower Titanium Valve Springs w/Keepers/Retainers
    Deatsch werks DW301 300lph Fuel Pump
    Ported/Polished STI Cylinder Heads
    AMR Performance 2.5in Uneven Length Header
    Perrin 1.8in Large Up-Pipe
    Torque Solution Shifter Linkage Inserts
    Perrin Intercooler Kit w/Back Coated Piping
    Perrin 3in Cat-Back Exhaust System
    Perrin 3in Down Pipe
    Garrett GTX3582R Turbo
    Perrin Rotated Turbo Kit
    Tial MV-R 46mm Wastegate
    >>>EXTERIOR<<<
    San Remo Red Paint
    OEM Projector Fog Lights
    Yellow 9005 Bulbs
    OEM Windshield Wiper Heaters
    Modded Front Bumper
    >>>INTERIOR<<<
    Full Premium Black Interior
    STI Style Heated Front Seats
    STI style Steering Wheel
    Optional Arm Rest Extension
    Sunroof
    >>>SUSPENSION/WHEELS/STEERING/BRAKES<<<
    STI Golden Big Brembo Calipers
    STI 13" Rotors
    STI 5x114 Hubs/Knuckles
    Cobb Lowering Springs
    STI OEM Shocks
    >>>AUDIO/ELECTRONICS<<<
    OEM 6 disk CD player w/6 speakers
    >>>STUFF IT ONCE HAD BUT NOW REMOVED<<<
    04-05 gunmetal 16" OEM rims (some bent)
    Stock DOHC J205 Engine (227hp/217tq)-Blew Connecting Rod Bearings
    02-03 WRX 16"x6.5" Rims w/205-55-r16 Hankook Tires
    WRX 5spd Transmission
    5x100 Hubs/Knuckles
    WRX Turbo Set-Up
    WRX Intercooler
    WRX Exhaust System
    WRX Rear Differential
    WRX Drive Shaft
    WRX CV Axles
    >>>NEAR FUTURE PLANS<<<
    17+ Rims or STI Rims
    STI Shift Knob w/Boot
    OEM Battery
    Front Fender Liners
    Restore Headlights
    STI Rear Hubs
    STI Flywheel
    Replacement Trans Dip Stick
    Replacement Front Right Knuckle
    DCCD System
    Fuel Rail
    Fuel Pressure Regulator
    STI Oil Cooler
    STI Dash Gauge Pods
    Electric Boost Regulator
    Boost Gauge
    Oil Pressure Gauge
    Oil Temperature Gauge
    Water Temperature Gauge
    >>>FAR FUTURE PLANS<<<
    20% Tints
    De-Badge
    De-Wing or STI Wing
    Replacement Dash Harness
    Replacement Rear Bumper
    Replacement Center Console
    Replacement Side Skirts
    Front Lip
    Replacement Front Right Door
    Replacement Trunk Interior
    Wire Tuck
    Trailer Hitch
    Replacement Dash Coin Tray
    OEM Rubber Floor Mats
    >>>MAINTENANCE WORK DONE<<<
    NEW Front CV Axles
    NEW Radiator
    NEW Rad Hoses
    NEW OEM Rear Main Seal
    NEW OEM Axle Seals
    NEW Serpentine Belts
    NEW OEM Water Pump
    93 Accord LX Sedan (sold)
    Looks like a good start, I have an 04 wrx there pretty fun cars!
    I would recommend the front and rear shift bushings they make a heck of a difference.
    Also Lexus es300 projector foglight are a direct swap if you open up the foglights.
    Originally posted by Darkcloud
    Wimp go low or go home haha
    Originally posted by cb7_tillidie
    Not a single fuck was given that day.
      Nice. That's a hard color to find.
      2013 Honda Fit Sport Alabaster Silver Metallic GE8
      2013 Accord Sport Modern Steel Metallic CR2
      CB9 http://www.cb7tuner.com/vbb/showthre...hlight=hostile
      CR2 http://www.cb7tuner.com/vbb/showthread.php?t=197787
      GE8 http://www.cb7tuner.com/vbb/showthread.php?t=199289
        Hey nice pickup!
        What you doing with the NY plates?!
        Ill take one if you don't want them LOL
          Very nice. Digging the red.
          1993 Accord EX
          2011 Subaru STi
            Wow, trying something new I see. Looks good...wonder what direction your headed with it.
            '09 Mini Cooper S (R56)
              Very nice. Do you have service records? Those things tend to have problems after 100k.
              Did one or both of the wagons have to go to make room for this?
                Say what?!?!?!?! You sneaky mofo!!!! Its looks great tho Gus!!!
                My coupe!!!
                Originally posted by Racer_XXX
                  I say none, just hoarding now.
                    I'm hoping that's the case. His mirror-image green 5th gen wagons were too nice!
                      Awesome!
                      Another subie owner! Nice pickup, wolf
                      BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
                      BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
                      Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
                      CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
                        neat things about the car that it has...
                        heated "racing style" bucket seats, ws wiper de-icer, dual piston calipers, dual rear cup holders, DRLs, headlights that shut off when the key is removed, clear 3rd brake light, MT dip stick, tweeters at the door handle, smoked headlights, metal pedal pads, sunroof, RPM gauge in the middle...
                        just got the shifter bushings the other day. my shifter right now is so loose. cant wait for it to get here. and Ill keep an eye for those. I had them on my CB9.
                        yup, noticed most are blue/gray/black here. and red is the only color you couldnt get in STI. plus its a premium package version. so rare on rare lol. and I do love rare stuff.
                        Originally posted by Ralphie View Post
                        Hey nice pickup!
                        lol I got these red/white ones, and the blue/white ones. and theres often alot of trade-in's at my job with NY plates. people forget them.
                        I hope I dont stand out to cops though
                        for now, OEM. just need a car that doesnt stand out to thieves like a honda does.
                        I saw the carfax. after all, I got it at work. it was a trade in. Im the 3rd owner. 1 was from NC, the 2nd was from FL. the 1st owner did take it to the dealer often. over all, nothing majorly bad with it. just small warn out stuff. no smoking turbo.
                        also I still got the wagons. safe & clean in the garage.
                        yeah the bmw 328i MT coupe was sold. :/
                        but now I got a car to take to the NE during winter. even salt proofed the bottom already.
                        Originally posted by AAPOQ View Post
                        Awesome!
                        thanks man
                          much needed...
                          what joy...
                            Why did you pull the motor? Nice dd , i like the color too.
                              I guessing , clutch work.
