Air vent broken, help!
    The fan vent to the right of the steering wheel is broken. I can move it up and down but I can't slide the vent left or right to change the air flow direction. Does anyone know how to fix this?
    Go to the junkyard and get a replacement. Those just pop out of the radio trim ring.
      Hey try this
      You can try to pry it up on the right side, on an angle and see if you can straighten it out it had happened to me once , and thats how i fixed it good luck. Billy
      Destiny Struggles To Reassert The Pattern That Was Meant To Be. Also Some Of These Members Are Wise Guys With There Wise Guy Answers . Also only inexperienced drivers put donuts in front . You can follow me but it's going to hurt!
        I agree they'll probably be almost free at the junkyard
        MRT= http://www.cb7tuner.com/vbb/showthread.php?t=193891
          Does it kill people these days to investigate the problem? Its so simple how it operates, take it apart and look at the little piece that connects the center vent where the slider is to the rest.
            Probly just one of these popped off. Calm down
            C-3PO's MRT USDM yo!
              Sorry, I just thought it would save time, and the risk breaking it, to ask here first.
              So how do I pry it out? It won't budge when I try......
                you literally just pry it out gently from one side. easier to pry from the middle piece that divides the 2 center vents. i have no idea what your doing to not get it out.
                  Use a small flat head screwdriver and thats weird u say it wont budge cuz as soon as u pry it out alittle it comes out very easily
                    Thanks for the help! I don't know why it was so hard to get the vent out (probably me just being an idiot) but I finally got the vent out and found the prongs had just popped off.
