H22 swap question
    H22 swap question
    I have looked and done some research but im going to be ordering a obd1 H22 for my cb coupe. The f22 has took a dumb on me after 240k on it. Can i just swap the motor and change the ecu and call it a day for now? I know about the powersteering bracket and HP line. Im just trying to get it running for the time bieng until my next paycheck. Thanks guys.
    http://www.cb7tuner.com/vbb/showthread.php?t=5423
    Swap FAQ
      Not quite a simple drop in and go.
      H22 swap list
      H23A-powered CB7 coming soon.....
        H22 swap list
        Yeah i saw that information but i overlooked this part...
        -1-5 wires, depending on make, model and technique, will need to be run from the ECU to the VTEC Solenoid, VTEC Oil Pressure Sensor, Knock Sensor and IAB solenoid (exc. EX w/A6) on the new motor
        Is there a write up on how to do it and i have an ex. Not sure if its an a6 motor but if i do then none of that extra wiring is required?
        thanks.
          I'm not using the IABs and I only needed to run three wires for VTEC. Ground, vtec pressure switch, and solenoid.
            Is there a how to on this? I have looked everywere and cant find anything.
              I'm not sure but call or text me and I will tell you how to do it. 6784597513
                Thanks man! im at work i'll text you in a few. Going to be from a 281 area code.
                  To determine whether or not you have an F22A6 you go out and pop your hood, look at the identification stamp below the head on the block and near the transmission. Or, failing that method, if your car is a '90-'91 EX you don't have IABs, but if it's a '92-'93 you do have them.
                    yeah i know how to find what engine it is i just cant remember lol. Im gonna do this swap at my shop but i just wanna ask questions cause i have had alot of hondas just never did a swap on one lol
                      You have my number and I text for free. Just give me a buzz anytime.
                        I bought my entire swap from a friend, when I picked up the parts he was still working on the car removing parts from it, he took off 5 wires from one of the plugs that go onto the ecu. These wires ran through the firewall and onto the vtec related sensors! Seemed simple! I'm gonna try to document that particular process when I do my swap
