It's a lot of work but absolutely worth it. I can't wait for the final result
That's why I'm going to use LED's an put some reflectors in my bumper.
As good as this looks, I should point out that you've just made your tail lights illegal by removing the reflectors. Unless you add a red reflective strip somewhere else on the rear of the car, you wouldn't pass an inspection or get out of a ticket for illegal tail lights.
Not only that, with the reflector and shroud removed, the lens no longer projects the light properly, and you would only be able to see the bulb from directly behind, and even then would look like a pin head.
I notice these are all 90-91 tails has anyone done them on 92-93? I did and Was able to get the outer ones apart but the inner (the ones on the trunk lid) seem to be solid plastic. After heating them up and trying to gently pry them apart I kept breaking off bits of the housing so I got scared of ruining the whole thing and stopped. They're extras so I'm not too worried but it's still money lost.
See those plastic tabs with glue? I drilled them out. That's wat gets caught on the inside and takes for ever to come apart. I drilled some out with my red clears. Came apart a lot better.
Now the reverse light is a seperate housung in its self.
I'm going to find inner tails at the yard and open them up for the hell of it.
