Originally posted by spiderpig
View Post
GMB Ebay Timing belt kit opinons
Majestic sells the OEM water pump with the gasket for
19200-P0A-003 001 001 WATER PUMP (YAMADA) $54.61
and the timing belt 14400-PT0-004 016 001 BELT, TIMING (113RU24 A-555) (UNITTA) $36.00
That's less than $100 for two most vital parts in that engine... Quit being a cheap a** buy the oem parts, fix it once fix it right and move on with your life... water pump and timing belts are the 2 thing no one should be cheap about it... just the time involved with replacing those is not worth the $50, at most that you will save....
I use alot of GMB parts and never had any problems with them, just buy them from a trusted source because there was an issue with knockoff gmb water pumps a few years back, you can tell them appart by the logo on the pump.
Ill check if i have any old pump at home and take a picture of the logo.
Usualy i have a bunch of em but im in the proces of taking over one authorized dealership so im not working these days.
