Lower balljoint replacement.
    I couldn't find a DIY about lower balljoint replacement after a few searches, but I found this one on Youtube. I'll share it with y'all.
    https://www.youtube.com/watch?v=tiwu...e_gdata_player
    Prime example of why it should be addressed as soon as possible! lesson learned
    Originally posted by Quashish
    Holy crap thats a clean F series. jellish mang.
    Quashish dictionary
    Jellish: (adjective) Jel-%i'sh+#
    To envy something to point of almost blowing a load involuntarily.
      EEEK!
      Why didn't you do the ball joints when you put the coilovers on?
        How, when and where did it break?
        What kind of roads do you drive on?
        How many miles on the car or on the failed part?
        Did it slip off?
        I'm curious to see up-close photo of it if you have.
        A&P-IA
          Do you have a Hayes or Chilton service manual ? If not its pretty straight forward . I would suggest both upper and lower balljoints as well as outer tie rods . You can rent a ball joint press for next to nothing from AutoZone . Or remove knuckles completely and take them to a machine shop and have them pressed out and new ones in .
            LOL, that video makes it look like a cake walk! I did my
            LBJs in 4 hours (2 hours each side) going casually slow and taking my time and using power tools, retaining ring pliars, pitman arm pullers, and a press.
              OUCH!
              I've to hurry up and fix it! And drive carefully, of course.
                This video shows a good method because they don't use press or any special tools, just a hammer and a pipe for the hard part for example. If you don't have issues on the way, it will be a cake walk literally.
                  EEEK!
                  They were just cheap coilover sleeve and were installed couple years back. Didnt notice any play in the ball joint, but it made minor creaking couple weeks prior.
                  Did it slip off?
                  At this point i drove the car about 100 miles a day with mixed road conditions but all city, no offroading or anything lol. The road i was driving on was fairly smooth traveling about 45 mph when out of nowhere i here a loud pop and the tire screeching extremely loud. i was able to control the car and pull it over to the right lane so no further damage was done. I'm not sure when the balljoint was last replaced but judging by what happened, i should have replaced it sooner. I needed a new axle, fender, tire, UCA and staiblizer bar
                  Quashish dictionary
                    Wow
                    Thank you for sharing.
                    It looks like it popped off from the knuckle. no?
                    A&P-IA
                      Looks like it's time for a new LBJ and an axle.
                      BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
                      BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
                      Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
                      CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
                        I dont get how it came out of the knuckle like that
                          X2^
                          The cup must be messed up.
                          Any pics of the knuckle where the ball joint slipped from?
                            That lower ball joint trick never works for me.
                            My swap thread
                            Main relay proplems?--DIY
                              i changed both of mine in like 2hours. i put the LBJS in the freezer and then put a bottle jack under the ball joint and heated and with the weight of the car it popped right out and went it just as easy.
