2 questions about an auto tranny.
    Any diagram to see how many screws have a tranny? I want to unmount it because a serious leak. (just the bell or housing, not the converter or something else).
    And, If I change the gaskets, do I need silicone or something additional on it? How do I apply it if it's neccesary?
    Thank Y'all...
    Your first sentence does not make any sense. "How many screws have a tranny?" The answer to that is none.
    How many screws does the tranny have that bolts on to the block? I can't remember quite honestly. Though the process of taking off your tranny is somewhat easy if you have another person helping you.
    Are you sure the leak is even coming from inside the transmission? What gasket are you talking about?
      Yeah, that's what I mean. My english is not the best because I'm not from the states. Maybe I'll write it on the signature. But you're smart and understand me.
      The auto transmission housing have 2 gaskets: One where the converter is and other near the speed sensor is. I need a diagram to show you.
      It's leaking there, and a little by the axle retainer. I'll fix all the leaking possibilities.
        which number in these diagrams?
        http://www.hondaautomotiveparts.com/...ISSION+HOUSING
        http://www.hondaautomotiveparts.com/...VERTER+HOUSING
        http://www.hondaautomotiveparts.com/...GHT+SIDE+COVER
          #5 in the first, #3 on the third.
