I've went through 3 now. I've used half a can of wd-40. So I have access to an air gun Wednesday, will this be safe? I need to keep my passenger side but replacing drivers cause of auto to manual swap. Any help or suggestions is appreciated
spindle nut keeps breaking breaker bars
use something better than WD40, i don't think that has the power to penetrate rust. I have personally had good results with Liquid Wrench. Maybe apply heat to the nut to get it to expand a little.
Worst comes to worst, you could always cut off the spindle nut and get a new one, who cares if you damage the threads on the driver side axle because just like you said you're going to replace it with a manual one.
Did you unstable the nut? It's not normally a big deal but sometimes people stake the hell out of those nuts when putting them back on.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by thepowderblue View PostAre you talking about the axle nut?
The only way I have ever used is a impact.
Also, this may be moot since you're too the point of breaking breaker bars but when I remove an axle nut I stick a #3 Phillips screwdriver into one of the games of the rotor so that it catches on the caliper bracket. Doing that coupled with someone pressing the brakes will ensure the rotor from spinning.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by Jarrett View PostAlso, this may be moot since you're too the point of breaking breaker bars but when I remove an axle nut I stick a #3 Phillips screwdriver into one of the games of the rotor so that it catches on the caliper bracket. Doing that coupled with someone pressing the brakes will ensure the rotor from spinning.
Originally posted by mtnbikaah View PostI've used just a 1/2" ratchet with a 5 foot pipe instead of a breaker bar, less movement. Have yet to break a Craftsman 1/2" ratchet. I've never actually used air or impact on an axle nut.
Yeah I'm not sure why you used WD-40... PB Blaster or like dude said Liquid Wrench would probably be best. And if you have access to an impact then that would probably be ideal though I've always just used a breaker bar.
Originally posted by Tippey764 View PostYou're supposed to remove the axle nut before you lift up the car or even remove the wheel.
Two reasons:
Most of the time I'm removing axle nuts is at the junkyard where the wheels are off and the car is in the air.
Also, I'd rather load the shaft of the screwdriver and the rotor than I would stress the axle shaft which in turn stresses the transmission. I'm not saying its not acceptable by any means. Only that I think my way is better for the reasons I gave.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
