MT bracket trim
    MT bracket trim
    Ok I know these 5sp swap threads are everywhere. What I'm wondering is what bracket do I order for my trim model. I have a 91 lx but the tranny came out of a 93 ex. So my question Is do I order the bracket for lx or ex or is there even a difference. Thanks
    Edit- I choose this route other than the ESP mount due to my wallet size
    There is no difference. The only difference in the transmission mount bracket is between auto and manual.
    You will need to weld the bracket in, so unless you're capable of welding, or you have someone that can do it for you, the cost of the bracket, labor, and manual mount could very possibly be as expensive as the ESP mount. ESP doesn't really like to sell just the transmission mount, as they prefer to sell the entire mount set together (the performance is just that much better with all mounts)... but I believe they WILL sell it separately if you ask for it.
      Yea they have it listed individually. I have the mount just not the bracket. My uncle is going to weld it on so cost would just be the bracket itself. I found it on majestic for $20. Thanks for the info on the trim, I'll just get my trim model (lx) thanks again
        Yeah, when in doubt, stick to your own year and model if there are different options.
        Many people just cut them off of junkyard cars... but if it's only $20 from Majestic, then that's worth it. If you already have the mount and can get it welded for free, then it's obviously the best route. Just be sure your uncle lines it up properly. If it's not welded in the right location, you could end up breaking axles like crazy.
          Yea I figure it'll be pretty inexpensive if I take this route. Are there marks for where the MT bracket goes or do a measure a certain way? I believe I read there's an 1 1/2in difference but which way? Thanks
            I'm not sure, as I've never done it... but I think cp[mike] wrote a DIY about it quite some time ago. That might be able to tell you for sure if you can find it. Chances are it's buried in one of the Swaps sticky threads.
              cool, once again I'll enter the search engine of knowledge lol. Thanks deeves
                Ok so I couldn't find anything on the placement to weld in the 5sp bracket. Surly I don't weld it where the auto went (what would the point be in that). Any help is appreciated.
                  There was only one person i knew that actually welded in the MT bracket and his name was Plee3. You're in luck because i remembered that and found his ride thread since he measured out everything and was nice enough to include pictures.
                  http://www.cb7tuner.com/vbb/showthread.php?t=138589
                    Awesome man, thanks
