Power Window Motor Hotwire
    Hi, my first post here. First off thank you all!! I've been reading these forums for a few years and you guys are really informational.
    On to my problem,
    I'm looking for a way to independently operate my drivers door power window..
    currently i'm on a 92 dx sedan with all manual windows, i decided to blow a brake line getting off the highway because i felt like smashing my car into a yield sign. luckily the only damage (except a dented 17" wheel) was to my drivers door, so i go back out to the junk yard and their were no 4-door manual window donors out there so wanting a window again i grabbed a power door and left. have it all on my car now, i just can't figure out how to hotwire my window.
    right off the window motor is 4 wires... blk, blu, red-yellow, red-blue. i'm in my haynes book looking at the wiring diagram it shows the 2 red wires go to the switch one up one down, blu goes to window ctrl unit, blk obviously off to a ground some where.
    using a working 12v source i thought ground the ground and then just power one of the 2 red wires and boom i'm operating my window but of course that doesn't work.... Any ideas on how i can just make this window move???
    Just swap the manual window crank piece in place of the power window motor if its still good
      my old door is destroyed, that is a great idea i could try another yard but in the mean time i want my window cracked open..
        Ah, i thought maybe only the regulator was belt/damage and maybe the manual motor survived
        Did you try ebay or craigslist?
          Not yet, I 'ma cut the old door apart and see if I can get that manual crank part out.
