h22a4 swap help
    h22a4 swap help
    so ive had this car for a year and a half, and ever since ive been wanting to do an h22 swap. is had an f22a1 in it since ive had it, and it finally blew up last week so i figured id go ahead and get an h22 to swap in there. got an h22a4 off cl tody for 200 bucks, but thats an obd2
    what all do i need to do this?
    first you better check the motor. for 200 bucks somethings bound to be wrong.
    COUPE K24
      Step 1, look in the Swaps section of this site. There, you will find everything you need to swap in an H22A and convert from OBD2 to OBD1.
      The H22A4 will most likely need require some modification to use the necessary Accord intermediate shaft.
        i looked in the swaps section and i couldnt find anything about obd2-obd1 conversions. and yeah the motor has a few problems, blown head gasked and low compresion in cylinder #2. i need to get some cam gears too, and the guy i got it from is a civic head and got tired of it takin up space in his garage. so i figured an h22 for that cheap cant be that bad of a deal lol
          It's going to cost you more to rebuild that H22 than it would to just buy one that's already in running condition. Not that the experience of building an H22 is a bad thing to gain, but I wouldn't say you took the cheap or easy way out!
          Use an OBD1 distributor, injectors, and ECU.
            if anything i might just try to trade it off for a running a1 so its all obd1 or somethin. idk. i might rebuild it, idk yet.
