I have A problem with my Motor ticking
    Ok I have recently changed my distributer and wires and etc. Then shortly after my belts for my alt and my powerstereing then the ticking began. I have an single cam F22 b motor could some one tel me what they think it is
    Have you check your valves?
    They may need reajustement .
    Where is the noise coming from?
    -->751 whp @ 27psi <--...Midnight Tuning <----
      Yeah, knowing where the noise is coming from would make it easier to diagnose. Chances are it's somewhere in the valvetrain. Mine ticked until I did a valve job and cleaned out the head.
        Refer to a service manual and do the following:
        Valve Lash Adjustment
        Note: Adjust every 12-20K miles depending on driving habits. The more exposure to high RPMs, the smaller the intervals. Factory adjustment intervals are every 15K miles for normal driving.
        INT .010 inch
        EXH .012 inch
        Motor Oil
        Use a quality motor oil to prevent valvetrain wear (rocker arm pad to camshaft lobe). Alternatives include adding Torco ZEP to conventional motor oils or using Torco SR-1 or similar quality oils.
        Note: Our CB7s typically have high mileage and many previous owners, history is critical. Valvetrain wear could have already occurred with grooves already present on rocker arms pads and respective camshaft lobes. In this case, you would have to replace camshaft with one in better condition and install new/better condition rocker arms onto your existing rocker arm assembly. Then, follow the above procedures to maintain.
